Thread: Object dissolve using a null
    Is it possible to "wipe" on a single object within a scene using a null to guide the rate and position of the opacity plane.
    Registered User fertilizer's Avatar
    Dec 2006
    london uk
    7
    Try using a clip map to affect the object's opacity. Take a look at this tutorial:
    http://www.md-arts.com/clipmapcutaway.htm
    The essential concept is that the position of the clipmap is determined by a null using 'reference object' in the clip map's texture editor.
    Engineer/Entrepreneur Sekhar's Avatar
    Sep 2005
    Pasadena, CA
    2,124
    If you want to dissolve whole object gradually, use the dissolve envelope ("E" under object dissolve in render tab of properties) instead - you could drive the dissolve using proximity to your null.
