Results 16 to 30 of 43
Thread: Surface Library [plugin preview]
  1. #16
    Quote Originally Posted by tajino
    Does modeler SDK allow non-modal panel and at the same time offers ctlviewport() like panel control?
    As far as I know, there is no non-modal control for Lscript in Modeler. There seems to be one in C++, because .p plugins can even draw live in the viewport.
  2. #17
  3. #18
    Newbie Member philraimbault's Avatar
    Nov 2006
    paris
    24
    I love it too.
    Philippe
  4. #19
    This looks FANTASTIC and it should be non-modal so maybe we can convince NT guys to convert this to ".p" and then have it in 9.2.x modeler ? Maybe if we all send Feature Request it would be with good result. Combine this wiht current presets editor maybe ?
    tajino - great effort and mostly very cool idea - that is some serious workflow boost. thanks
    RAM-Studio
    WS - Dual Xeon E5-2698v4/128GB/Win10x64/4xRTX 2080Ti
  5. #20
    Netherlands
    5,560
    Exceptional!
    What a nice plugin...
  6. #21
    Hi all, sorry for the long wait, here it is at ver0.8
    http://www.tajino.net/misc/SurfLib/S...odeler_0.8.zip
    please read the readme.txt before running the plugin.
  7. #22
    excellent, i'll give it a go!
    mlon
    lw_chanlum [free shader and node x32] <HERE!>
    lw_chanlum [advanced node x32, x64, ub and osx] <HERE!>
  8. #23
    any mac version under development? or does it work wit macs as it is?
    markus
    3dworks visual computing
    demo reel on vimeo
    instagram
  9. #24
    Quote Originally Posted by 3dworks
    markus
    lsc, i think it should but not sure.
    anyone interested in improving this plugin, 'port' as a C plugin, will send you the source.
  10. #25
    lsc, i think it should but not sure. ...
    seems to have problems here when trying to select folders. i can only select a file, not a folder as path.
    markus
    demo reel on vimeo
    instagram
  11. #26
    markus
    forgot to mention, lscript modeler does not have folder requester.
    So when browsed to the desired root path of your library content path, say "L:\markus\library" just leave nothing selected, and click 'open' or equivalent on the mac.
    In the filename field you should see "Select this folder" as the filename, just leave it as that.
    please try again see if it works.
  12. #27
    the problem is that as it is i can only chose a folder containing files. no enclosing folders are selectable. if i put a dummy file into there or if i select a file, i get error 'line 1208, illegal arithmetic operation on data type".
    afaik there are some mac specific problems in lscript, but unfortunately i never had time to get into programming...
    markus
    demo reel on vimeo
    instagram
  13. #28
    my lw crashes after i added the plug and close modeler.
    after restarting modeler i could select the surface preset folder but gave me an error after and it couldnt find any subfolders (which there are).
    lw9.2, amd xp 2000+, 1gb ram, w2kpro.
    mlon
  14. #29
    it succeeds also me..
    Luciano Peluccio
    www.vis-art.it
  15. #30
    Quote Originally Posted by -EsHrA-
    mlon
    could you try looking in your registry, \HKEY_CURRENT_USER\Software\Newtek\Lscript\
    look for value name "LibraryGeneral_librootpath" and check if the string is indeed the root content paths of your actual library path
    library path is just a typical content directory, so if your library path is D:\library\, then the string should be that as well.
    in the D:\library\ should then have at least subfolder of "images\" and "surfaces"
    and in the "surfaces" folder should have at least one subfolder could be anyname, the subfolder could even be empty.
    hope it works.
    also while in the registry if you have selected custom path, look for "LibrarySurface_LibraryMode" the value should be "1".
