Results 1 to 8 of 8
Thread: edge loops
    Apr 2007
    in a galaxy far far away...
    11
    edge loops
    i come from the program blender so i am not sure what the LW term is for this but,how do you and a edge loop to a sertain part of the mesh?
    Hastings, New Zealand
    7,731
    What method did you use in blender to create or control edge loops?
    Apr 2007
    11
    i would just push the edge loop hot key and it would show a line on the mesh were the edge loop would go.that probably dont help mush but i don't know how to explain it?
    7,731
    You can use bandsaw with split edge turned off to see which polygon loops will be cut before actually cutting them. You can also use the select loop tool.
    satellites & astronauts ercaxus's Avatar
    NY
    620
    If Fi's Jigsaw still works in 9.2 you can select a poly loop and run Fi's Jigsaw and interactively move the cut. I like it better then bandsaw.
    Quote Originally Posted by ercaxus
    Bandsaw-pro does it interactively as well.
    NY
    620
    I meant "drag mouse in viewport" style interactive, not using sliders, but for more precision and multi cuts bandsawpro is better.
    You can use "select loop" in modeler for polygons, points and edges but first you must select TWO of them so that LW know what direction you want to go.
    RAM-Studio
    WS - Dual Xeon E5-2698v4/128GB/Win10x64/4xRTX 2080Ti
