Results 1 to 13 of 13
Thread: Fprime 3 Nodal Textures
    "I drank what?" Imatk's Avatar
    Los Angeles
    270
    Ok so what do I have to do to get Fprime 3 to show me nodal textures in the preview window??
    So far as far as I can tell it doesn't do anything differently than Fprime 2.
    I'm running Vista... could this be it?
    Thanks for any help.
    Jamie Clark
    SamJam design
    Running 9.2 Open Beta? (you don't have to answer that!)
    What always gets me is the check box for nodal textures (I forget to check it.)
    Quote Originally Posted by jmcinnis
    That's what I was thinking. Fprime 3 should be showing all your nodes, no problems.
    NewTek Moderation NTComm's Avatar
    San Antonio, TX
    121
    Moved to LightWave - Third Party forum section.
    There are already FPrime 3 threads in both LightWave - Community and LightWave v9.2 Discussions. If you would like to start additional threads, you are welcome to do so and this is the appropriate forum section for that.
    Los Angeles
    270
    I'm running 9.0 at home and yeah I made sure the checkbox was activated.
    I did a test render natively and it looked like it should... but not in FPrime 3.
    Jamie Clark
    SamJam design
    Cow Orker cagey5's Avatar
    Manchester UK
    3,273
    Quote Originally Posted by Imatk
    Your answer is there. The SDK mods have been instigated as part of the 9.2 upgrade. It's still not too late to jump aboard the OB bus.
    Forum Tips
    If English is your first language, you should know it's 'losing' and not 'loosing'!
    Stuttgart, Germany
    13,659
    It needs 9.2, 9.0 doesn't have the hooks for FPrime to evaluate nodes.
    Cheers,
    Mike
    Can anybody confirm FP3 looses geometry in high poly scenes - like over 1m.
    3DBob
    Phone me for free on
    Skype
    My user ID is tir-3dbob
    Stuttgart, Germany
    13,659
    Quote Originally Posted by 3DBob
    Yeah, I've had some issues as well, loosing complete items though. I haven't had the time to thoroughly check it though.
    Cheers,
    Mike
    Thanks Mike,
    I've had objects dissapear in the renderer but not previewer. But if you take a subpatch - say a landscape - and crank the divisions up - it seams to stop accepting data when it has had enough.
    mmm
    3DBob
    Skype
    Los Angeles
    270
    Aaah ok thanks very much that makes sense... thought I was going a bit batty there
    Jamie Clark
    SamJam design
    Triglycerous Gluteous Dave Jerrard's Avatar
    Apr 2005
    Burbank
    1,061
    3DBob
    I ran into that as well. I've only got 2GB, so that might be the problem. FPrime loads the scene into its own memory, so I've likely used it all up and FPrime grabbed only what it had room for.
    He Who Really Needs To Go 64 Bit Soon.
    Last edited by Dave Jerrard; 03-26-2007 at 12:14 PM. Reason: Wow. When I blow my nose, it looks like an advanced species too.
    - Any typos are the result of a creative, yet rebellious keyboard.
    ASUS KGPE-D16 MB
    2 AMD Opteron 6272 CPUs
    32GB Kingston KVR1333D3D4R9S RAM
    EVGA|01G-P3-1556-KR GTX550Ti video card
    hmmm..i've lost objects too. But I seem to have a work around..
    Select you object, and use replace it with null. then reload mesh by replaceing the null with the object again.
    Don't ask me why..but it works. (you'd be suprised what a desperate man will do to find workarounds)
    anyhow..that being said, did you lose your geometry when you made a change to it? I did. So i wonder if it's a "connection" issue rather than a memory issue.
    Anyhow, thank god it works fine now.
    Good luck guys.
    BTW.. the surface baking feature is a LIFESAVER. Remeber you need 9.2 though ;-)
