Results 1 to 15 of 16
Thread: What's making my screengrabs fuzzy?
    Registered User THREEL's Avatar
    May 2006
    Bryan
    1,226
    Question What's making my screengrabs fuzzy?
    I was wondering if someone might know the cause behind my fuzzy screengrabs. They're nothing more than printscreens saved as JPEG files.
    Any help is greatly appreciated.
    tHREEL
    San Antonio, Texas, USA
    13,056
    Looks like you need to turn up the quality of the JPEG. JPEG is a 'lossy' format that 'throws' data away when you turn down the quality (or increase compression).
    UI / UX Designer @ NewTek
    incurable dumbass Medi8or's Avatar
    Norway
    803
    Try png instead. For wireframe and node-tree screengrabs, it's pretty much unbeatable.
    My dongle is small, hard, and purple.
    Sydney
    8,279
    High compression value?
    Registered User Andyjaggy's Avatar
    Sep 2003
    Utah
    4,327
    Yep looks like good old JPG compression. If you want a cool printscreen utility check out Gadwin Printscreen. It's free and does all sorts of cool things.
    May 2006
    Bryan
    1,226
    tHANX for the feedback everyone. The thing is, I wasn't having this kind of problem, until the last 3 or 4 times I grabbed a screen to share info here. I must of accidentally changed a setting somewhere. I'll look into your suggestions and get back to you.
    I thought that maybe I just needed stronger glasses.
    Do you only notice the degration in quality when you open up your saved file? If I print screen into Paint Brush or PhotoShop, no compression has happened until I save it. If it looks fuzzy before saving, then that would be strange.
    Actually looks like a low resolutiion video image [640x480]. but yeah, if you save a file to .jpg format at say low quality you will soften the image. kinda how years ago all digital cams and video cams had soft look due to limited resolution.
    May 2006
    Bryan
    1,226
    Quote Originally Posted by Martin Adams
    Nope, it only gets fuzzy after I export it out of the illustration program I'm using.
    Quote Originally Posted by JamesCurtis
    I think you might have just hit the nail on the head. Do you have any suggestion on what settings would be appropriate to get rid of the fuzzies?
    Netherlands
    5,560
    JPEg Setting 6~8 or 'High' will usually do the trick.
    Perhaps use another 'illustrator program'... which one are you using?
    May 2006
    Bryan
    1,226
    Quote Originally Posted by Exception
    CorelDRAW
    I try to set the compression/quality levels to keep the file size below 1 meg. If the file size goes above 1 meg, I have trouble uploading it to the forum.
    13,056
    Medi8or is right, for screen shots where a lot of screen is the same colour, PNG would be better. JPEGs are better for photographs, or images with LOTS of changing detail.
    May 2006
    Bryan
    1,226
    Let's see how this looks. This is a screengrab saved as a PNG file.
    160 x 120
    May 2006
    Bryan
    1,226
    Here's Take 2.
    1024 x 767
    This is just an even aspect ratio of the one-to-one size.
    May 2006
    Bryan
    1,226
    Ohhhh, much-o better-o!
    Don't you think?
    I'll have to remember PNG when I'm saving Screengrabs.
    The projected file size was over 40 meg, but the end file size was just under 90 k. Go figure.
    tHANX everyone, for all your help!
