Thread: Help in conversions (TrueSpace to Lightwave)
    Jun 2006
    Here
    98
    I have a model of a Bridge from Star Trek: The Next Generation and I am attempting to convert it from truespace to lightwave so I can animate a sequence. I am faced with problems when I use Deep Exploration to convert it. I am getting like over 4500 objects and something unusable.
    Now, this only occurs if I name the object something that is usable. What happens is that in Deep Exploration, it sees the model with many axes and such and makes everything a separate object (I believe).
    I was just looking for a way to import this bridge and make it really easy to use. I have enclosed a picture of the bridge for your pleasure.
    Registered User Andyjaggy's Avatar
    Sep 2003
    Utah
    4,327
    well if DE won't do it I don't know what to tell you. Try converting it in DE to something else besides LW and then converting it from that format to LW.
    Jun 2006
    Here
    98
    I was converting to 3DS Max but no help
    Give AccuTrans 3D a try. It can convert many formats. You can find it here http://www.micromouse.ca/
    If you go to the downloads sections you will be able to try out the 30 day trial version.
    Jun 2006
    Here
    98
    Thanks that program worked great!
