Page 4 of 4 FirstFirst ... 234
Results 46 to 54 of 54
Thread: Speededit interface very slow
  1. #46
    no the jpg files are now renamed.jpg.vtb what is that?
    Way off base Newtek does make folders (unwanted all over my computer, even in sections I never use SE.
    The Problem is sample: myphoto.jpg get's renamed myphoto,jpg.VTB what is that? that is NOT a jpg format I have ever heard about
  2. #47
    19,397
    I seriously doubt that SE is actually renaming your files. You are correct, however, that is does create the NewTek Info folders. I don't believe it creates them in any location that you don't navigate to at least once using the Filebin.
  3. #48
    Registered User ted's Avatar
    Fresno, CA
    4,216
    For what it's worth, I was navigating on my old Trinity/Globecaster system today and was finding old "play" folders all over the place.
    Ted R. Ruiz Sr.
    Ad-Venture Video Productions
    Elite NewTek Dealer
    www.editbay.tv
    TriCasters, Most All Models
    Cameras-Mostly HVX 200's
  4. #49
    Nocturnal Crouton Flinger JackJ's Avatar
    May 2006
    Oklahoma
    135
    Hmm...not sure how its happening (and I'm away from the system right now) but I think .vtb is the extension thats generated when you trim or alter clips on the timeline and then drag them back into the file bin. Instead of .jpg, it reads as .jpg.vtb (I think), and if you grab that one and drag it back onto the timeline, it will have the same changes/duration as the one you dragged in there.
    Is there a chance that the files are being saved with additional, SpeedEDIT specific information for some reason?
    JackJ
  5. #50
    Registered User KiloWatkins's Avatar
    Sep 2006
    New MexKilo
    1,029
    Your save after capture to another (Newtek) codec should fix this for now. Please do send John what he needs, so he might find something new for the codec/format or changed since they included it for SE. Send your Cache in Prefs to another drive, other than the drive SE is on. Turning OFF some Pref settings, rollover projects and previews can help. And NEVER close SE down with a folder of pics in the filebin showing. When you startup SE again, it will want to load all the pics befor SE will start, and if rollovers are on in Prefs, make thumbs.
    GoodLuck
    GoodLuck KiloVideo
    Digitizing video since 1984
    HyMPG Designer since 1997
    Avatar says, 89.3 MPG Avg.
    [email protected]
  6. #51
    Creator of BobFX for VT Bobt's Avatar
    Plainfield, IL
    1,319
    Name is changed but its n Icon representation of the file.
    Thats whats in there.
  7. #52
    19,397
    Quote Originally Posted by JackJ
    JackJ
    What your referring to here is a 'file instance', and yes you are correct. This is not a full-fledged duplicate of the source file - really just a small file comprising a file pointer and relevant metadata. The file extension is an indication of that fact, not an error.
  8. #53
    May 2006
    Oklahoma
    135
    Sure, Steve. Just wondering if something in the way they're capturing or manipulating the folders is causing the instance extension to show up, or if its something out of their control, like the way SE is dealing with a codec (maybe tacking on metadata from the camera somehow)
  9. #54
    19,397
    I'm not clear why you might prefer it hidden. It essentially represents a very useful 'handle' for a special case version of the source file, though not the file itself. The extension makes it identifiable for what it is. Not trying to be argumentative, honestly - just not following, probably my fault.
