Hello,
I'm preparing a short animated film for rendering. It is intended to go straight to DVD. I don't anticipate having to put it to film, but you never know. Test show it will be feasible to do it as a near 2k render size at about 20 minutes in length.
My first question is... is it ok to render to a size like 2350x1000 square pixels when making a movie for DVD? My initial tests look good with nice fine details in the images, I'm wondering if it is overkill for going direct to DVD. Half that size still looks good, saves on a lot of render time, but loses the finer details. I've tested a number of resolutions including 1080p and variations on 1.85 and 2.35 sizes, I haven't settled one an exact res though.
Part two of my question is, since I don't plan to go to actual film with it, does it matter if I render to the size I want with square pixels, or should I actually render to something standard like 2048x1556 with pixel aspect set to 2.35? As I understand it, 2048x1556 is sized to take advantage of the area within 4 perfs of film. Since I'm planning to be all digital with it, my thinking is to just go for the best quality render, the best render speed, and easy on my workflow. I'm not sure of any last minute hazzards that might pop up if I don't go with a film standard.
One other question that ties into the other parts is, I'm encoding with Adobe Premiere and Encore. The first encoding tests using presets turned out looking bad, very compressed and jaggy. I'm assuming it is just that I am new to this version and haven't dialed in the settings I need. I would guess this is professional enough software to make good encodings. Should I outsource for pro encoding? Does the resolution I render to have a bearing on the quality of encoding output? I'm looking at other animated feature films and see lots of nice detail throughout, I would like to get something close to that with my CG movie on DVD.
Any tips or experiences or examples to point to are most welcome.
Thanks,
Bill C.
