Thread: More Getting Started
    Feb 2007
    California
    4
    I'm an editor and purchased 3D Arsenal because it appeared to make using 3D fairly easy.
    I have viewed the tutorials and they all seam to pick up after the conclusion of a different tutorial so I never seem to get to the beginning, how do you START using this product? Also to make matters worse I have just switched from the PC to the Mac and I'm not at all confident that I installed the application correctly.
    After starting LW I got to File>>Load>>Load Scene>>[dir] Macintosh HD/3D Arsenal Master Content/scenes/3D Arsenal/(pick any file)3D Arsenal Flags/flagwave1.lws >> I get the following error messages -- File Not Found, can't find "Objects/Flags/flag.lwo". Select an alternate file?
    If I select "no" the scene loads without the object but if it had motion or a lens flare for example they play fine.
    I also find it interesting that there is no help file, I hate to admit it but I really don't mind reading the manual.
    I'm sure I might have installed something incorrectly but I have no way of knowing so I'm just looking for some help in getting started correctly.
    Can we use the phone support? They where very helpful when I called for the key.
    Feb 2007
    California
    4
    Never mind.
    After reading the suggestions from a similar post on this forum I was able to figure it out.
    I guess part of the confusion stems from the fact that the tutorials aren't really in the order I expected. If there have been others confused by this issue I'd suggest that you direct the user to start with the General Lightwave Tutorials first followed by the 3D Arsenal Tutorials.
    I am in the process of redoing all the get started tutorials and they will be available on line and with the new rebranded product soon.
    They will be in a specific order meant to be followed.
    I appreciate the input and will make it more understanable for first time users.
    Don Ballance
    Director of Training for NewTek
    Co-creator of Newtek's Award Winning 3D Arsenal
    [email protected]
    Aug 2005
    Gainesville, GA
    1
    I am switching to 16:9 video. How do I get 3DA into that format?
    May 2007
    Stoughton WI
    107
    3d Arsenal is 640 x480
    My default setting in 3d Arsenal is 640 x480.
    I would like to know too.
    You can set any custom resolution in the camera panel.
    There is also a setting for wide screen to set the 16x9 aspect.
    Don Ballance
    [email protected]
