Thread: screamernet on mac pro
    Dear friends, I own a Mac pro quad intel based,... and I'm looking forward to buy a new one to make a renderfarm,... and before I read all the manuals
    and threads posted here wich are quie dense,...... could somebody tell me jus fast if there is possible to use screamernet,. (Or a similar program),. to use both macs pros in a renderfarm successfully,... joined with a ethernet cable?.
    thanks a lot for somebody who could help
    Super Member avkills's Avatar
    Mar 2004
    Denver, Colorado
    1,363
    Yup. I'd suggest looking at one of the Mac based render node controllers though.
    You could actually run 3 nodes (save one for controlling; technically you could run 4) on your main machine and 4 on the MacPro, although it may just be easier to use one MacPro as a render machine on its own.
    -mark
    You can get a lot of bang for the MacPro buck, but it may not be your most cost-effective solution. Base MacPro is a quad proc, so you get up to 4 nodes per MacPro, with a limited amount of RAM. For a similar price, you can get 3 or 4 Mac Minis, which will get you 6 (or 8) render nodes. You may want to compare render times on a mini vs. the MacPro, and see what the differential is. If the MacPro renders more than 30% faster per CPU (i.e. 1 min. per frame on the Mini >= 45 sec. per frame on the Pro), it's the best price. If the per frame difference is smaller, you get more processors for less money with a mini farm.
    "One of the things we really have to impress upon people is that it is never good to be fed on by a blood-sucking insect"
    Dr. Anthony Marfin, CDC
