Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
Thread: Batch rename layers; replace sub string
  1. #16
    Code Muppet evenflcw's Avatar
    Stockholm, Sweden
    2,642
    It's Lscript language syntax, not regexp syntax. The ~ is the regexp operator in lscript. Just like + is the addition operator. It's really all there is to it.
    Ie.
    x+=y is equal to x=x+y, where + applies y on x and assigns the result back to x.
    x~=y is equal to x=x~y, where ~ applies y on x and assigns the result back to x.
    In the latter case y is supposed to be a regular expression and x a string. So the expression is applied on the string.
    PS. I'm not sure if ~ standalone is valid in lscript or if you can swap the places of x and y. Something in the back of my head says it couldn't be done, but I could remember wrong. But I think the above is still a good way to think of it. Ie. just another operator that takes two operands.
  2. #17
    Stockholm, Sweden
    2,642
    Looked at the previous post. My first guess is that layers which have not been assigned a name by the user might not actually have one. Ie the value returned from layerName(index) might be nil (ie. not a valid string). So you're trying to apply a regular expression on nil (undefined both in type and value) which is invalid. Do a check before applying the regular expression.
    Second guess, the regexp() function is buggy with empty string replace. Although that seems unlikely.
    Nitpick. You really only need to create the expression once. It's reusable. So put that line, exp=regexp(myfind,myreplace);, outside the loop.
  3. #18
    Not to scale BlueApple's Avatar
    Nov 2005
    Los Estados Unidos
    1,026
    Quote Originally Posted by evenflcw View Post
    Just what I was looking for; thanks. Perhaps the LScript documentation I have is old, or maybe ~ just isn't in there.
    As to your suggestions on how to fix the script, thanks again. I will give it a go first thing in the morning.
    Adam Martin
    my portfolio
    Mac Pro 2x3Ghz Dual-Core Intel | 8 Gb RAM | OS 10.6.8 | ATI Radeon X1900 XT
  4. #19
    Nov 2005
    Los Estados Unidos
    1,026
    Made the adjustments that evenflcw suggested and am now very close.
    Code:
    @version 2.2
    @warnings
    @script modeler
    main
    	myfind="_";
    	myreplace="";
    	mymesh=Mesh(0);
        mydata=lyrdata();  // returns an array with all the non-empty layers in it
    	exp = regexp(myfind,myreplace);
    	for(index=1;index<=mydata.size();index++)
    		myname=mymesh.layerName(index);
    		if(myname != nil)	//check if the layer is unnamed
                lyrsetfg(index);
    			myname ~= exp;
    			setlayername(myname);
    The problem now is that we are not getting through all of the layers. This is because the for statement only performs an iteration for every layer containing data.
    Consider an object with nothing on layer 1, and then a cube on layer 2. mydata.size will equal 1 so only layer 1 will be examined. We never get to layer 2.
    I tried looking at the last index in the lyrdata array, however that array lists integers for the layer numbers in the order that the layer data was created. The last number in the array is not necessarily the last layer number containing data.
    Do I need to dump lyrdata into a new variable, sort it, grab the biggest number there, and use that in my for statement?
    Adam Martin
    my portfolio
  5. #20
    Stockholm, Sweden
    2,642
    Hehe... "hjärnsläpp" (trans:"temporary brain loss") as we say in swedish. Happens even to the best.
    I think processing all layers up to the highest layer number mentioned in lyrdata (and lyrempty even?) sounds like a good idea.
  6. #21
    San Antonio, Texas, USA
    13,056
    Arrow
    Try this ...
    Code:
    @version 2.2
    @warnings
    @script modeler
    @name "Layer Rename"
    main
    	find_string = " ";
    	replace_string = "_";
    	current_mesh = Mesh(0);
    	// Put all the non-empty layer info into an array
    	layers = lyrdata();
    	// Put all the empty layer info into an array
    	layersempty = lyrempty();
    	// Find max index of non-empty layers
    	max_layer = layers[layers.size()].asInt();
    	// Find max index of empty layers
    	max_layer_empty = layersempty[layersempty.size()].asInt();
    	// Create search / replace expression
    	exp = regexp(find_string,replace_string);
    	// Loop through all layers until we hit the max layer
    	for(index = 1; index <= max( max_layer, max_layer_empty ); index++)
    		// Grab the current layer name
    		current_layer_name = current_mesh.layerName(index);
    		// Don't do anything to unnamed layers
    		if(current_layer_name != nil)
    			// Set layer to foreground
    			lyrsetfg(index);
    			// Rename layer
    			current_layer_name ~= exp;
    			// Set new name for layer
    			setlayername(current_layer_name);
    Also added more comments for those wanting to learn LScript, and renamed some variables to be nice and clear.
    UI / UX Designer @ NewTek
  7. #22
    Nov 2005
    Los Estados Unidos
    1,026
    Success:
    Code:
    @version 2.2
    @warnings
    @script modeler
    main
    //This script will go through an object in Modeler 8.5 and remove the "_" from all layer names.
    	myfind="_";
    	myreplace="";
    	mymesh=Mesh(0);
    	aTemp = mydata; //creates a duplicate of the array.
    	aTemp.sortA();	//sorts the array
    	for(index=1;index<=aTemp[aTemp.size()];index++)
                lyrsetfg(index);
    			myname ~= exp;
    Thank you all for your assistance.
    Adam Martin
    my portfolio
  8. #23
    13,056
    Arrow
    Quote Originally Posted by BlueApple View Post
    Success:
    Not quite
    It fails when:
    • The object has no geometry, but has named layers
    • Doesn't catch empty but named layers after any layers with objects on (see attached JPG)
    Attached is the script I modified above, but with a simple UI on it to allow easier entering of search / replace strings.
    Works in all situations, including the two points mentioned above.
    Attached Files Attached Files
  9. #24
    Nov 2005
    Los Estados Unidos
    1,026
    Quote Originally Posted by Matt View Post
    It fails when:
    I should've said it works successfully for my situation. I don't need to perform this operation in the two scenarios you laid out. However making the script handle more situations, and the UI are welcome additions so thank you.
    I ran your script on the attached object and it appears to rename the first two object layers and then stops. I populated the first box in the UI with an underscore and left the second box blank. Any thoughts?
    Adam Martin
    my portfolio
  10. #25
    13,056
    Arrow
    Fixed, turns out saving an object with blank layers between populated layers changes the lyrdata() and lyrempty() arrays so that the highest layer number may not always be the last (as it was when I tested it).
    Added sortA() to both which solves the situation.
  11. #26
    Nov 2005
    Los Estados Unidos
    1,026
    I'll check it out when I'm back in the office, Matt. Thanks for your assistance.
    Adam Martin
    my portfolio
  12. #27
    Super Member geo_n's Avatar
    jpn
    4,677
    This is cool. Will try this out. I needed to rename a lot of layers in modeller and I could have used this. I always liked Mike Green's MGrenamer in layout and wish it had a version in modeller.
    I'm also using a surface global renamer that adds prefix and suffix as well. Forgot who made it though.
  13. #28
    Nov 2005
    Los Estados Unidos
    1,026
    I think that those lyrdata is populated with layer numbers in the order that geometry was created in them. If you make a box on layer 1, 2 and then 3 your array will read [1,2,3]. If you first make a box on layer 3, then layer 1 and finally layer 2 you will get [3,1,2]. I didn't do a lot of testing to confirm this but it seemed to be the behavior I was seeing.
    Your script is great, and the UI is a wonderful addition. Thanks again for your work on this, sir.
    Adam Martin
    my portfolio
