Results 1 to 15 of 18
Thread: Panasonic HVX200 & Raylight & SE
    Aug 2005
    St. James NY
    49
    Will SE be able to use DV FILM's RAYLIGHT so that Panasonic's HVX200's P2 footage can be used? If anyone from NEWTEK is listening please let us know. Thanks.
    Registered User ted's Avatar
    Fresno, CA
    4,216
    From what I hear. not in 1.0. But I'm confident it is a priority to NewTek and will follow shortly.
    Ted R. Ruiz Sr.
    Ad-Venture Video Productions
    Elite NewTek Dealer
    www.editbay.tv
    TriCasters, Most All Models
    Cameras-Mostly HVX 200's
    Registered User chuckd's Avatar
    Houston, TX
    208
    Actually, 1.0 should be able to use DVCPro HD via raylight just fine.
    Chuck Dotson
    visual concept productions
    Aug 2005
    St. James NY
    49
    SE 1 and HD & Raylight
    Will anyone at Newtek confirm this... please.
    Fresno, CA
    4,216
    We have used Raylight into AfterEffects and output to an .rtv from DVCPro 1080 and 720 already in VT 4.6. It's just too much workflow for most of our productions.
    Ted R. Ruiz Sr.
    Elite NewTek Dealer
    www.editbay.tv
    Houston, TX
    208
    Ted, were you using the Raylight DVfilm codec? If so, try using the other one-- it doesn't need to convert the entire file, saving gobs of time and hard drive space when using it.
    There's simply no reason it wouldn't work with either the current VT-Edit or SpeedEDIT. It installs a little application that includes the codec itself and is seen as an .avi file by any program that can read them.
    Chuck Dotson
    Aug 2005
    St. James NY
    49
    Codec
    Which other one are you refering to. Ray Light works terribly with VT 4.6C.
    Fresno, CA
    4,216
    Chuck, I'm honestly not sure. But I remember going through the RL-AE-VT was too much of a pain to pursue. Plus we kept getting a fielding issue no matter how we rendered it.
    I'll check tomorrow if I get time.
    Ted R. Ruiz Sr.
    Elite NewTek Dealer
    www.editbay.tv
    Beyond Reality WizCraker's Avatar
    Clovis New Mexico
    1,410
    It is much easier to use a Firestore DVCPRO HD. The Panasonic HVX200 just saves in the native format and then you take the FireStore to you NLE and edit away... The cool thing is that you can edit directly from these things or just dump it to your storage array.
    There is a local TV Station that has about 3 or 4 of these cameras and they use the Firestores to bypass tape.. They then just use the Media Composer Adrenaline and Final Cut Pro NLEs to edit down the footage.
    ImageReality.com
    "Relax...it's just an update for the patch to fix the nerf that nerfed the fix for the update of the patch that broke the fix that was fixed."
    Late 2013 MacPro 12 Core
    XDCAM HD production ScorpioProd's Avatar
    Albany, NY
    4,346
    But still, you guys are talking about some significant workarounds, no?
    I mean, it's been said that SE 1.0 isn't made for this stuff. So until a future version of SE can support it natively, is it really worth doing now with SE?
    Eugene
    Scorpio Productions
    4,214
    Eugene if the visual quality is there and the needed editing features are there then "Why not use SpeedEdit?". Even using workarounds mentioned here the benefit would be not having to use a massive rendering program like Vegas or Final Cut. If the workarounds allow users to still quickly edit without having to be locked to antique editing methods, then I am all for it.
    IF the workarounds needed to use SE take longer or the visual quality is worse than using a competitor then just use the competitor.
    EDIT:
    I was pleasantly assured that the Panasonic P2 workflow is definitely something that SpeedEdit will address in the near future. It may not be in 1.0 but it will be soon there after.
    Jef Kethley
    PIZAZZ
    www.pizazz.com
    Using:
    Panasonic UB300 4k cams
    Albany, NY
    4,346
    I agree, Jef, I'm just saying I tend to view Ted as having the vanguard experience with it and he said it was very cumbersome.
    But yeah, if it works, and it's what the user needs, sure.
    Of course, even SpeedEDIT will still have to render out the final product. Rendering isn't a thing of the past by any means.
    Eugene
    Scorpio Productions
    Toaster Oven
    Maryland
    1,145
    Quote Originally Posted by PIZAZZ
    ...I was pleasantly assured that the Panasonic P2 workflow is definitely something that SpeedEdit will address in the near future. It may not be in 1.0 but it will be soon there after.
    But I can't resist... one has to wonder what "Near" and "Soon" mean!
    Registered User Keith Nealy's Avatar
    Big Island Hawaii
    153
    But first we have to understand what the meaning of "is"....is.
    No more mindbenders until we get that one figured out!
    Another eggnog please.
    Keith
    Keith Nealy Productions
    Big Island, Hawaii
    Feb 2004
    Orem Utah
    78
    I purchased Raylight Decoder and was NOT able to drag and drop raw Panasonic .mov footage into my timeline. I had to convert it in After Effects into something Speed Edit likes.
