Thread: Rotating/Translating Camera help
    Hello All;
    I am not new to LW but I have always had a problem since day 1 with positioning the camera. I am using LW9 and have a fairly complex model loaded into Layout. I've spent all morning trying to get the "perfect" view I want and am no closer to it now that I was when I started.
    It seems that I am having extreme difficulty moving in all three axis's (When translating. It seems that I can move closer/further but not up or down.
    Similar Problem with rotating, I can roll, and yaw but can't pitch.
    Is there some important concept that I'm missing ? Could I have a setting wrong, or something ? Is there any trick to positioning the camera that makes it so easy. I have heard that I should use the camera view but that is pretty useless if a few of the rotation and translation controls don't work.
    Can someone give me some tips that they find helpful? Thanks much.
    Tim
    Are you in Camera view '6' (Numeric Keys), cos if you are you can't see the the handles of the camera to move it around from here, even so holding down Control or Command in either mode should allow you what you want, but most people use '4' to go to perspective view so as to see their Camera Controls and if you want to look through you camera as well as see it at the same time toggle 'F3' to look at all the split view port options
    LW Board Lurker Extent's Avatar
    Bay Area, CA
    344
    Also, right click dragging will move your object on the 3rd axis in any viewport.
    "I am interested in entertaining people, in bringing ... laughter, to others, rather than being concerned with 'expressing' myself with obscure creative impressions" -Walt Disney
    Levanthia.com
