Results 1 to 11 of 11
Thread: matte and shadow objects
    Oct 2006
    canada
    27
    Hello Everyone
    can someone help me to understand how I apply a matte shader to my objects
    I just can't to figure it out or where the shader is locate
    I just want to make a simple scene with a sphere and a floor and one light
    I want the sphere to cast a shadow on the floor . but I dont want te floor to be seen.
    Thanks in advanged for all the help
    Engineer/Entrepreneur Sekhar's Avatar
    Sep 2005
    Pasadena, CA
    2,124
    In Surface Editor, under the Advanced tab, for Alpha Channel, try Shadow Density. On render, you'll get your matte in the alpha channel. I think this is what you're looking for.
    Oct 2006
    canada
    27
    Thx Sekhar
    I tried it out but it didn't work . maybe I need to active something else
    so it will work ?
    basically if my backdrop is white and I want my floor not to be seen in the
    render , but I want it to get the shadow that the sphere cast .
    it will make the effect of infinte floor or kind of a studio shot .
    that's what I want .
    Sep 2005
    Pasadena, CA
    2,124
    Well, you just get the alpha channel for matting out the floor, not the final image. On the Image Viewer (that has the rendered image), choose Alpha instead of Image on the top right. You'll see the matte covering the object(s) casting the shadow and the shadow itself.
    To use this matte, save the render as Photoshop 32 and use the alpha channel to matte out the rest of the floor that you don't want. Then composite this on the background (in this case just a white layer) in Photoshop. If this is an animation, you could use a compositing software like AE.
    If you want a more direct approach, check out the "Front Projection" option under Texture in Surface Editor...though in this case since your background is simply white, you could just match the floor color and get a similar result.
    Sep 2005
    Pasadena, CA
    2,124
    Here's a simple example, if you need it.
    Attached Files Attached Files
    Oct 2006
    canada
    27
    Thx For all the help Sekhar
    The second method did the trick for me . but this only works if I got
    a one color background
    so I'll need to learn the first method too
    the problem is that I don't know how to make a layer to mask another layer
    in photoshop
    if you could give me a brief explantion on how to do it I would be so happy
    I'll also try to check for tutorial on that on the net
    and again thanks for all the help and sorry for all the truble .
    Sep 2005
    Pasadena, CA
    2,124
    No problem pawn, glad to be of help - that's why we're here.
    Here's how you can apply the alpha:
    (1) Open the image in Photoshop
    (2) Go to the "Channels" tab and Ctrl+Click on the alpha channel (bottom)
    (3) Go back to the "Layers" tab and click on mask icon at the bottom (third from left)
    You now have the matte applied. You can then add the background as a layer below this matted layer.
    Oct 2006
    canada
    27
    Thanks Thanks Thanks and again Thanks for all the help Sekhar
    it worked like a charm .
    Sep 2005
    Pasadena, CA
    2,124
    Glad it worked out, pawn.
    Those interested in the sample, please use the below instead - in the earlier one above, I forgot to save the LWO with Shadow Density set for the floor.
    Registered User bagou01's Avatar
    Sep 2007
    Ličge - Belgium
    158
    hey,i got the very same problem,except that my shadows are not completely opaque,and that's to be put over an image,and not a white background.so how can i extract only the shadows,and not just the alpha,as when grey,the alpha will let appear some of the texture under my shadows ?
    like in max for instance on a matte shadow material, the material itself is transparent but the shadows appear.
    allons 'fi,ca n'a aucune alluuuure
    Sep 2007
    Ličge - Belgium
    158
    and to add that it doesn't seem to work with the shadows created with radiosity,the blurred shadow become sharp edged...
