Thread: Timewarp screws Alpha Channel.
    Registered User ivanze's Avatar
    South America
    622
    Is this a bug? When I render something using Timewarp it screws the alpha channel. You can check it with the Image Viewer and it won't save any alpha in your sequence files either.
    South America
    622
    Anyone?
    Registered User ScottSullivan's Avatar
    Jun 2005
    Philadelphia, PA
    188
    Confirmed. I just tried rendering out a very simple object moving up and down with nothing else in the scene.
    Rendered it out with standard animated camera move. Alpha was fine. Applied the Timewarp and the alpha is solid black.
    I'm using Win XP Pro, Service Pack 2, 2 Gigs RAM, LW9 (obviously).
    Scott
    Jun 2005
    Philadelphia, PA
    188
    Just tried using Image Filter's Buffer Export. Same result: no alpha.
    More bugs?!
    Ahhhhhhhh! Get them off me!!! [and outa LW too!]
    South America
    622
    Thnx ppl, and the sad thing is that you can remove the timewarp from your scene, save it, and load the scene again, and the alpha is still screwed.
