Results 1 to 11 of 11
Thread: Node Displacement
    Unknown Cavern
    930
    Node Displacement
    Ok you Node Guru's out there. I got something for you!
    I want to bend a plane around a null based on it's distance to the null. So the closer the null gets to the plane, the more it curls around it.
    Figure that one out!
    I spent most of my evening trying to. I started trying ripple but I couldn't tell Layout I only wanted 1 wave. I tried gradients, but no matter what I did, the plane would just move 1m per 100% of the alpha channel.
    So tired, going to bed and hoping Santa Node will have left me a forum present in the morning.
    Current system Specs:
    4gb ddr2 1066
    dual 9600 gt (512mb each) running SLI
    9600 black edition amd
    780a nvidia chipset
    XP Pro or XP Pro 64 or Windows 7
    Super Member warrenwc's Avatar
    Nov 2005
    Tulsa, Oklahoma U.S.A.
    903
    Use a weight map (or a morph map)& a gradient instead.
    Make the weight map a radial gradient & animate the control gradient.
    I think it can work but I cannot try it right now because of thunder & lightning (the way you love me it's frightning. I better knock....on wood )
    Warren Christiansen
    Core i7 3.2Ghz
    12GB Ram
    Windows7 64
    Geoforce GTX285
    Working Monkey StereoMike's Avatar
    Luebeck, Germany
    1,931
    Man I'm old... I know this song...
    Mike
    If you are not paying for it, you’re not the customer; you’re the product being sold.
    How Old? Really? Aww Heck colkai's Avatar
    Staffordshire
    7,808
    Ahh, see, different strokes...
    made me think ... 'god.d.a.m.n. it's so exciting, it hits you, like a hammer, god.d.a.m.n." ..followed by uber-cool guitar solo
    Too old to die young.
    Nov 2005
    903
    ANYWAY...
    now that the storms have passed, does that suggestion help at all?
    If you're trying to actually wrap a flat plane around something, it might have to involve bones or more than one object.
    Or possiply even cloth effects.
    Warren Christiansen
    Core i7 3.2Ghz
    12GB Ram
    Windows7 64
    Geoforce GTX285
    Unknown Cavern
    930
    what I want is to create something like a bullet hole where all I have to do is place a null near the surface and it will deform the surface. So all I need is 1 ripple. And the size of the hole is to be based by the distance of the null from the surface. I can then create a surface node that can color the object.
    4gb ddr2 1066
    780a nvidia chipset
    Nov 2005
    903
    An aplha map in the form of a circle would probably be easier.
    Parent it to a null & size the null for the deformation.
    Look at the scene(if you dl'd the content) where the bug is under the rug.
    Warren Christiansen
    Core i7 3.2Ghz
    12GB Ram
    Windows7 64
    Geoforce GTX285
    Unknown Cavern
    930
    Which scene is that?
    4gb ddr2 1066
    780a nvidia chipset
    Unknown Cavern
    930
    I think I got it. I am going to do some tests. And I used something different then explained above.
    I don't think I can have multiple holes, but it is a start.
    Edit: make that I can! HA!
    4gb ddr2 1066
    780a nvidia chipset
    Unknown Cavern
    930
    Here is an example with 3 holes
    Now if I can only figure out how to color this crap.
    4gb ddr2 1066
    780a nvidia chipset
    Nov 2005
    903
    Quote Originally Posted by MiniFireDragon
    It's called bug_in_rug in the displacement folder.
    If you're using nodes, just copy your displacement nodes & paste em into the texture node editor.
    you'll have to tweek a little, but the sizes & placement will match.
    Warren Christiansen
    Core i7 3.2Ghz
    12GB Ram
    Windows7 64
    Geoforce GTX285
