Thread: shading noise reduction button in lw9?
    shading noise reduction button in lw9?...where did it go?
    in lw8 it used to be on the global illumination tab of the light panel...now in lightwave 9 is not there...because the radiosity panel moved to the render blobals panel...yet in the radiosity tab in lw9 there's no button to press.....
    err...why?
    stee+cat
    real name: steve gilbert
    http://www.cresshead.com/
    Q - How many polys?
    A - All of them!
    I'm a Registered User monovich's Avatar
    Rocky Mountain High
    1,526
    it's in render globals now. under the render tab.
    ...cheers again!
    not where i'd a put it...seeing as it works in conjunction with radiosity and doesn't help the noise in the ambient occlusion shader at all for example...
    well at least they kept it!
    stee+cat
    Q - How many polys?
    A - All of them!
