Thread: Where is the 'scale' tool?
    Newbie Member CreepinJesus's Avatar
    Jul 2006
    Switzerland
    19
    I'm following a tutorial for a model and it says to scale some points using the scale command. I'm using v8.5..I guess it's possible the scale command has been removed from an older version? If so, what do I use instead, and if it hasn't, then where is it?
    It's the size tool. or for scale in only 2 axes the stretch tool. Both under Modify -> Transform
    Jul 2006
    Switzerland
    19
    Righto
    How Old? Really? Aww Heck colkai's Avatar
    Staffordshire
    7,809
    There is both stretch and scale, normally these are assigned to 'h' and 'Shift+h' respectively.
    You can also alter the "mode" so the action takes place based on mouse position, origin, pivot or selection. Check out the bottom edge menu in modeller for these options. Scale / Stretch can be found in 'Modify->Transform' in LW8.5 & LW9
    Too old to die young.
