Thread: using the viewports
    Apr 2006
    USA
    20
    using the viewports
    i thought I'd use my first post on this forum to ask a really embarrasing question.
    I'm having a very dificult time navigating the perspective viewport in modeler. it seems that no matter what i do, LMB or RMB, all I'm able to do is rotate my object up or spin it on it z axis. Very frustrating.
    I've seen video tuts where that demonstrate that I am the problem here, not LW.
    What is the trick to using the perspective view?
    thanks for any help.
    Alex
    Registered User DrTWT's Avatar
    Nov 2005
    Red Sox Nation
    127
    hold down the Alt key and LMB; this allows you to rotate freely in perspective (and layout).
    took me a while to figure this out as well
    "There is no body cavity that cannot be reached with a 14 gauge needle and a good strong arm."
    Rule #5 of The House of God
    www.proceduresconsult.com
    Another tip on navigating. Select a point and hit Ctrl-A. The viewport will now rotate around that point.
    Not sure if it's the same on Mac or what the Mac equivalent to that is.
    Unregistered Guest Sarford's Avatar
    Feb 2006
    Amsterdam
    1,187
    Use Alt+Ctrl+left mouse button to zoom in or out
    Use Shift+Alt+left mouse button to move around
    This are the buttons on the mac... translate them yourself for the pc
    Apr 2006
    USA
    20
    DrTWT, hrgiger, Sarford.....thanks very much for the assistance. no problems now.
    Thanks again,
    Alex
    Netherlands
    5,560
    Yes, and use the 'g' key to focus quickly on an area, and the ',' and '.' keys to zoom in and out via keyboard. 'a' fits everything in view, shift-a fits selected...
    using all of these together is one happy navigation circus
    Kansas
    1,614
    Uh, I had a brain freeze. .... Oh, with LW the viewport is as if looking through the camera. Some apps use the object perspective, so it can be a little confusing if switching between apps where the rotation is different. THat took a little getting used to.
