Results 1 to 15 of 25
Thread: best autorigger
    open for interpretation Gettarobox's Avatar
    May 2003
    do you really care???
    382
    best autorigger
    I was just wondering if anyone had a recommendation on what the best auto rigging plugin or whatever is out there. I don't want to spend time rigging so if there is an alternative .
    At the moment, there's only three viable options. One of them is ours, but I'll try to be unbiased.
    1. Maestro
    2. T4d rigging tools
    3. ACS4
    There's another one on the horizon called LCS evolution. It's been in development for a while, and the last word I remember seeing was that there was some problem holding it up.
    There also used to be "The Setup Machine", but it's no longer available from what I understand.
    LSC is different from all the others in that you place nulls in Layout to fit your character, and the bones are created there. In all the others, you place skelegons in your model and the rigger converts them and applies the rig.
    There's been rumours that ACS4 is no longer being developed, but I don't know if that came from the source. Aside from that, my personal opinion of ACS4 is that it's too complicated and difficult to use. I spent hours trying to rig a character with it, and never got it to work. At $120, it's also twice as expensive as T4d, without adding much if any value for the priice.
    T4d is straightforward, easy to use, and inexpensive ($60). The rig it creates isn't real sophisticated, but some animators prefer a simple, straightforward rig.
    Maestro is really a different kind of package from the normal autorigger. The rigging part is really a macro executer, so in addition to the provided rigs, you can create your own command files and use it to do just about any repetitive task in LW. You can also edit the rigs we provide, so if they're not exactly what you like, you can customize them to fit your needs. The rigs provided with Maestro are also more comprehensive than the other riggers provide. For example, I think that Maestro is the only rigger that provides a facial rig. Also, it's got a lot more controls for things like fingers, and complex hip movement.
    The other major component is the control panel, which is like a joystick controler for the entire character, or any item or channel in Lightwave. This is a very quick and powerful way to control your character. The controller also has a timeline/keyframe editor that's really nice, and some added features like pose and motion saving/loading, etc.
    The price is $150, so it's the most expensive, but you're really getting a complete animation environment that is much better for character animation than native Lightwave.
    Okay, so I don't know if that was as unbiased as it should have been, but I really do think Maestro is cool. I can't imagine doing character animation without it.
    Eric
    you'd also be well placed to learn rigging as well...so that when a autorig doesn't offer you a solution for a wacky characters with 10 arms and 5 legs....you can rig it yourself...or at least have a go!
    have a look at the ikbooster video that's here on the boards today and also lok at some of the training available from splinegod and 3d garage.[videos for sale tutorials]
    stee+cat
    real name: steve gilbert
    http://www.cresshead.com/
    Q - How many polys?
    A - All of them!
    i also think u cand download some kind of DEMO from Maestro and from T4D, so u can give it a go.
    both are pretty good..i have meastro 1 and the td4's latest...
    the td4 uses standard items so you can move the rig around to other users who maybot have any rigger and it will work okay for them..meastro is a more refinded solution and does a stack of other stuff too.
    [ btw i've not spent a whole load of time with them as i use another 3d app for animation at present]
    the demo is the way to go...see which you prefer.
    stee+cat
    Q - How many polys?
    A - All of them!
    Registered Abuser
    Oct 2004
    UK
    165
    i'll add another one.
    this is very simple, straight forward, [but sometimes thats all you need to get started..] and i used it to do some really quick stuff.
    SimpleRigger [252 KB] : Based on the skelegons of an object, this plug-in creates a medium-complex rig. Contains plug-in, description, sample object files
    http://www.animationsnippets.com/plugins/index.html
    CG bloke.
    Registered User ScottSullivan's Avatar
    Jun 2005
    Philadelphia, PA
    188
    I'll throw my 2 cents in. Maestro is well worth it. I've got Maestro 2 and it just ROCKS. I started doing CA from Tim Albee's Character Animation book, which really goes into detail. At the time I was just getting to know LW as a program, so it was a little more complex for me. But it's a great book.
    However, after learning LW a bit more and playing with Maestro more and more, I just fell in love with it. It's so easy using it to animate, then go back and add your facial animation. Not to mention that while Tim's book really goes into detail, I didn't prefer his method (weight maps). That was really my only gripe. Maestro uses bones, which I prefered.
    If you add the info from Albee's great book and the interface in Maestro, you've got a great package that literally can grow as you do since Maestro has the ability to add customized hotspots. In the end, I used Tim's exercises and thought process within Maestro to learn to animate.
    Great job to the guys at Stillwater!
    Cheers,
    Scott
    D a r t h W a v e r Nemoid's Avatar
    Italy the great
    1,388
    one of the best was TSM the setup machine, but its dead for Lw
    I'd go Maestro
    Nemoid | Illustrator | 3D artist
    .::Creating for you::.
    Co-founder of
    www.lwita.com italian/english Lw forum
    May 2003
    382
    thanks for the help everyone. i know a bit about rigging already but really just want to focus on modeling and animating. i have the Albee book but it seems awfully painful to set up the weights and stuff. I think i will try Maestros demo since it seems to be more than just an auto rigger.
    thanks again guys.
    Netherlands
    5,560
    I just tried Simplerigger, and although it looks nice, so far for me the goals are not working at all... If I move a goal null, the object doesn't move one bit. Only when I rotate them.
    Edit:
    Perhaps I should have tried with ENABLe IK on... I didnt even know that button was there...
    sigh... I should stick to buildings
    So, I must say, simplerigger wors quite nice...
    Hastings, New Zealand
    7,731
    Quote Originally Posted by Gettarobox
    thanks again guys.
    Ive done tons of rigging and have never ever had to use that many weight maps. Typically I add the bones and start testing deformations first to see where things need some help. My first choice is to use hold bones because theyre easy to add and I can see the results immediatly. Also many problems can easily be anticipated in the modeling stage. Doing simple things like spreading the arms, legs and fingers a bit can greatly reduce any need for weight maps by reducing any cross influence you might get from bones.
    Basically if weight mapping will take X hours to do then worst case is the same X hours regardless if you do it first or wait to do it last. Usually I find that I either dont need weight maps or only very simple ones. So my worst case ends up taking very little time by waiting until the end. This way I can minimize the rigging time and focus more on animating.
    I prefer to also just reuse my own rigs. Its pretty simple to do in most cases. Im also using IKBoost more and more as a primary rigging and animation tool. Those rigs are very easy to reuse as well.
    Im not big on autorigging anyways but I would also highly recommend maestro. I think the power it gives to scene control in general greatly outweighs anything else it does. Its a great way to control your character and anything else going on in your scenes the need orchestrating.
    I think ACS4 could be the best autorigger out there, but unfortunately, Lukasz doesn't seem to be putting any more work into it to keep it current.
    Believe it or not I always thought you had to weight map at one time
    but I know better now
    Maestro is is the way to go not only for rigs but prettty much anything nice at controling lighting rigs as well using your own images if you want to get really into it as back grounds you could design virtual lighting boards etc......
    The posiblities are endless
    And no I don't work for them
    Either Lead, Follow............. or get out of the Way!
    7,731
    I know what you mean! When weight maps first came out The highest bone falloff was ^16 so they were needed. Later Newtek added in ^32,^64 and ^128. At that point even Newtek said that with those new falloffs that WMs were not needed nearly as much.
    That was about the time that vertex paint was released and the first thing I did was have it create weight maps for every skelegon. I quickly learned never to do that again because fine tuning so many weight maps was a source of great pain. I also learned that holding off on using them until after really checking out deformations first saved me a lot of time.
    Lightwaver Cobalt's Avatar
    Northern Virginia
    324
    Maestro Is Pretty Freakin Good
    I hate to admit this, but I don't have the time, patience or interest to learn the true art of character rigging. My "hats off" to all the TD's out there that do that kind of thing for a living. So I have tried just about all the auto riggers available for Lightwave and I think Maestro comes out ahead of the pack.
    The skelegon to rig process works very well. All you have to do is adjust one of the many pre-built skelegon rigs to your model. I didn't even fool around with weight maps and the deformations looked really good right out the gate. The hot spot controller is really cool and works well ... though you need to take an hour or so to test what each hot spot can do for you. There is a "pose" saver that I have used a few times without problem.
    Apparently, this is just scratching the surface of what Maestro provides. I still haven't taken a look at the custom key frame editor it provides.
    Last note, while Maestro rocks and the other auto-riggers have all been OK for me in the past, I have found nothing that lets me animate a single character like Sega's Animanium. It's down right fun. You can switch back and forth from IK to FK quick as can be. It reminds me of playing with action figures when I was a kid. The model and rig conversion process is long and painful process though and I haven't really used it in a real project with a deadline yet ... or maybe ever.
