Thread: Inserting a Pause In Animation
    hello..
    i am animating a camera fly-around in a scene and wish to insert a pause in the cameras motion at certain points along the way, however when i copy the last keyframe to a later time with the same values as the last keyframe.. the camera still moves...
    im sure theres a simple fix...i am relatively new to LW and must be overlooking something....
    would appreciate any help!
    thanks!
    Newbie Member joschy's Avatar
    Aachen-germany
    95
    Hi ebrett,
    check your key tensions in the graph editor. The default is the TCB spline.
    So, when you make a key twice on different key times there will be a "rubber band" between the keys. This make the move.
    You can set the second key to linear or
    change the Bias from the first key to (-1).
    thanks
    will give that a try!
    thank you!
