Results 1 to 15 of 18
Thread: Take a new look at Symmetry
    Super Member animotion's Avatar
    NY
    979
    I think Newtek should take a good look at symmetry in Zbrush, this is how symmetry should work.
    Symmetry in LW is a little okward and at times, its like trying to model while looking in a mirror.
    I have done binary coding in the past ans It seems like this should be something that is very doable.
    Animotion.
    Dance Commander WCameron's Avatar
    Wilmington MA
    546
    i'm still suprised that since we first got it, we still dont atleast have a switchable symmetry. Symetry on Z, or Y or X. I'm hoping its in LW9...
    - Will.
    "All those with Psychokinesis, raise my hand."
    - The Doctor.
    The Room With No Doors
    by Kate Orman.
    8,288
    Quote Originally Posted by animotion
    That's because you have to place geometry in the right side and edit only this part.. Second mirrored leave untouched..
    Binary tree for what? LW SDK has nothing to support Symmetry.. Each tool has to check whether Symmetry is turned on or off and do everything manually, which in case of creating new points mean scanning the whole layer to find -x,y,z (where x,y,z is original point), for polygons this starts to be really complicated because you have to do such scanning for the all polygon points.. If tool does really complicated stuff it has sense to use binary tree, but *each* tool must be written this way independently!
    In such limited by LW SDK environment it's impossible to make the all tools having Symmetry working in other axes than X right away, and this process would take a few LW releases to finish.. And in unsupported older 3rd party plug-ins - never..
    Therefore half year ago TrueArt made plug-in to make virtual copy of geometry http://virtualmirror.trueart.pl
    It works with EVERYTHING, current, older or never, does not matter.. You could make primitive Box and it'll be visible on the oposite X axis right away while you keep dragging handle points.. Watch video made by Proton..
    NY
    979
    "That's because you have to place geometry in the right side and edit only this part.. Second mirrored leave untouched.."
    I already know this, and the plugin you mentioned. All im saying is that it is possible (look at zbrush and other aps) and it would sure be nice.
    Animotion
    8,288
    Possible in *new* application - of course..
    But not possible in LightWave using current LW SDK, and with supporting the all tools written so far by either NewTek and 3rd party programmers..
    Quote Originally Posted by Sensei
    It's a terrible shame, if it's not possible to implement this in LW. Anyone who spends a lot of time modelling in the perspective viewport. Would appreciate it.
    Having the points behave consistently, (intuitively), across both halves of your object, would only improve the LW experience. It would also validate the notion of modelling with Sub-D's, being like, using digital clay.
    I'm totally with animotion on this, and hope we see it in a future release of Lightwave.
    "We've gone on holiday by mistake"
    8,288
    Quote Originally Posted by parm
    In LightWave it's possible go different route: instead of having Symmetry working with true geometry, having virtual geometry created by something like VirtualMirror.. With A VERY LITTLE NewTek help it would be possible to have this virtual part each polygon selectable like normal true polygon.. And you would quickly forget which part is virtual and which is true, but remember this just when you had to mirror for real..
    D a r t h W a v e r Nemoid's Avatar
    Italy the great
    1,388
    while virtual mirror is a hot plugin for sure, i'd like to have the simmetry mode fixed as well, because its built-in. also a good thing would be to support other axis, y, and z . difficult? i dunno. ZB has this behaviour buit in, plus smart simmetry to fix your model in case of problems, and it works. true that most other apps don't have simmetry mode : they rely rather on mirrored instances. it all could work with fixed points along center line, and no extra polygons created in the middle, as it happens for example in maya.
    Nemoid | Illustrator | 3D artist
    .::Creating for you::.
    Co-founder of
    www.lwita.com italian/english Lw forum
    8,288
    Quote Originally Posted by Nemoid
    It's far from calling it "built-in".. Symmetry in LightWave is nothing else than switch on/off.. There is no any function in LW SDK that support it, every single tool has to do this manually after checking whether it's on or off..
    Difficult in new application? Partially, but possible..
    In the LightWave? Impossible.. Due to rewritting a hundered of built-in tools, and hundered of 3rd party tools, to get it working..
    Italy the great
    1,388
    so you're basically saying that it cannot be enhanced. i am sorry about it. however i don't have great problems into using it. sometimes it breaks, but ita not difficult to restore simmetry. but, actually i'd like it never break.
    p.s. i am aslo wondering why simmetry has some probs also in Modo, which is a new application. i hope at least is a base and reworkable thing there.
    Co-founder of
    Game Developer
    Aug 2005
    San Diego, CA
    167
    Quote Originally Posted by bryphi77
    Because its a new application made by the same people, who like making the same mistakes twice. Modos splines suck too and have a striking resemblance to LW's.
    LOL on the splines comment, so true. :-)
    NY
    979
    My mommy told me that anything is possible, just close your eyes and click your heels twice and say....................
    8,288
    Spline modeling in Modo..
    When EasySpline was half baked, I saw the first time Modo video showing spline cage that is patched in the real time.. It looked great! Now I have the same (f.e. mixing Catmull-Rom curves with Bezier curves in the same spline patch) and even more (support to any length curves, crossing multiple other curves- this is what I've not seen on Modo video)..
    And are you saying that it sucks? What is wrong with it.. ?
    8,288
    I don't know if the vid you watched is for modo 2, but as far as the demo I downloaded, the spline workflow was very similar to lightwaves... does not patch in real time like easy spline
    You might be surprised in that case..
    I don't remember original movie address, but I put it temporary to my server.. Don't watch it directly, Save As.. to disk first..
    http://www2.trueart.pl/Graphics/Movi...plineDeity.mov
    It might looks awesome for the first sigh, especially because Modo guy is very very comminicative, and has *really* nice things to show..
    The only differences between TrueArt's EasySpline and Modo 201 spline patching:
    - EasySpline analizes layer after each permanent geometry change (add/remove point/poly).. When point position is changed spline patches are not evaluated, but splines that use these points are refrozen.. The same with spline patches that use these splines.. The rest remain the same..
    - Modo analizes it once when the all edges are converted to spline patch edges, later user has to delete some curves to tell spline patch that patch must be re-evaluated to find new curves, or spline patch should be removed..
    - Bezier in EasySpline is little differently implemented than in Modo (where spline using Bezier is crossing the all control-points).. EasySpline has single Bezier or B-Spline, Modo has Bezier or group of Bezier, but no B-Spline..
    Proton sent NewTek management EasySpline videos and they were not interested in purchasing it for LightWave v9.. When they have the first time in history chance to be quicker and better than Modo.. With little LW SDK changes it's possible to have spline cages in the RENDERING STAGE, without freezing them to polygonal model.. Can you imagine model that has milion polygons in rendering and in spline cage just a few dozen (especially if you use Bezier and B-Spline) or in maximum a few hundered points?
    i surpose it depends on where newtek's focus is for lw9...
    maybe chracter based stuf is higher priority..though spline patching DOES relate to characters also...or maybe they have stuff like this in lw9 anyway??
    stee+cat
    real name: steve gilbert
    http://www.cresshead.com/
    Q - How many polys?
    A - All of them!
