Thread: Dynamic Objects
    Sep 2005
    Van Buren, AR
    2
    Dynamic Objects
    OK, I am very new to LW. I would like to add a dynamic object in Layout. My add dynamic object box is greyed out. Please help!
    Thanks!
    You can allways create a Null ("^N"), open the properties ("p"), in the "Dynamics" tab add the dynamic effect you want.
    Dance Commander WCameron's Avatar
    Wilmington MA
    546
    re add the dynamic lscripts in the \Plugins\lscripts\interface\layout
    that start with add_
    those dropdowns on the interface are lscript helpers that basically do
    what kruemel_1 posted above automatically for you.
    this problem is usually an indication that something happened to your
    config files and you may need to add Other plugins that may be missing.
    Usually people recomend rescaning in your plugin folder, but only do that
    if you know for sure there are no double plugins in there. Like different versions
    of Worley plugins for instance, they'll both get added in will probably give you
    problems.
    - Will.
    "All those with Psychokinesis, raise my hand."
    - The Doctor.
    The Room With No Doors
    by Kate Orman.
    Sep 2005
    Van Buren, AR
    2
    Will / kruemel_1,
    Thank you both for your help! I did get the null to work and I also added the lscripts and now all works fine.
    Thanks again!
