Thread: Rendering wireframe?
    Mar 2006
    Minneapolis
    4
    I'd like to render a plain lighted background with a wireframe globe. I can handle the background and lights. But how on earth do you render a single object as wireframe?
    Registered User DrTWT's Avatar
    Nov 2005
    Red Sox Nation
    127
    Play around with the edges tab in object properties (in Layout). Or, the best way IMO uses the plugin found in this thread:
    http://spinquad.com/forums/showthread.php?t=6427
    "There is no body cavity that cannot be reached with a 14 gauge needle and a good strong arm."
    Rule #5 of The House of God
    www.proceduresconsult.com
    Heir to the Throne RedBull's Avatar
    Apr 2005
    Underground
    1,608
    You can just choose - Render Outlines in the advanced tab of the surface editor.
    This will make the object a wireframe....
    You can do a save transformed, if you need a wireframe mesh of it..
    Otherwise, just Render Outlines box, will be fine..
    Mar 2004
    Northern New York
    5,254
    If you want to make permanent wireframes, there is a plugin called truss2. It will make 2 point polys with the edges. Then it is up to you if you want to keep the rest of the object, as they are split up into different layers.
    Silk
