Thread: Lightwave .cfg files for tools
    Ive noticed that Lightwave automatically writes .cfg files for tools to the same directory as the content directory. I really don't like all those extra files in there, is there a way to chnage the directory that Lightwave writes these files to?
    Kansas
    1,610
    You can read the manual, but to change the config directory use -c in the shortcut then add the path. That's the way you'd do it if you wanted to have multiple versions and not interfere with each other.
    San Antonio, Texas, USA
    13,055
    This has bugged me for a while too. The -C config switch doesn't fix it either.
    UI / UX Designer @ NewTek
    Stuttgart, Germany
    13,613
    Actually, that is up to the developers. Dumping them into the content is just the simplest thing to do (basically, if a plugin opens a file without specifying a path it gets opened in the content).
    Mind you, I think for certain configuration files (that are more project centric) this makes sense.
    For most of them it doesn't though.
    Cheers,
    Mike
