Thread: Gold disc anistrophic effect?
    Jun 2005
    Reading UK
    3,137
    Just wondering if anyones has some settings that will produce the specularity associated with gold discs? I know about the BDRF shader, but not getting the required results.
    Cheers for your help!
    i7 X3930/32GB/Quadro 4000
    A thousand years from here
    3,352
    Well, that can be done with just a bump.
    Create a UV that goes around the disc, and assign a bump map that is simply nothing but a striped (and somewhat stipply (is that word? )) image.
    I have no special talents. I am only passionately curious. - Albert Einstein
    visit my company site : House of Secrets
    visit my personal site : svenneve.com
    UltramegaOK Triple G's Avatar
    May 2003
    Los Angeles, CA
    426
    A surface like that relies more on reflection than specularity. Which makes sense, since specularity is just a cheat which is meant to simulate reflected light anyway. So put something in your environment for your surface to reflect (luminous white cards, an HDR image if you have one, etc.) and you'll be well on your way.
    Gregg Domain
    Visual Effects Artist
    www.greggdomain.com
    Get Into Adobe After Effects
    Jun 2005
    Reading UK
    3,137
    Thanks for the advice - will give it a try
    LightJustice Panikos's Avatar
    Nicosia Cyprus
    1,727
    Denis Pontonnier lately ported some Renderman procedural textures. Look @ Flay.
    They include Radial, Spiral etc
    You can apply a radial bump on the disk very easily
