Results 1 to 15 of 30
Thread: Amb Occ. Renderer: Faogen
    Check it out. Only problem I am having is that LW doesn't have a MTL file so it's not doing a good job, so I can only do vert renders. But still cool none the less and REALLY fast.
    http://www.rusteddreams.net/faogen.html
    If anyone knows of a good OBJ export for LW, let me know!!
    Lamont G
    Artist Ubisoft Osaka/大阪
    Sydney
    8,283
    I've written an mtl loader/saver so you should be good to go. Download it from my web site and let me know how you get on
    Dude, it freakin' works!! Have at it LW'ers!!
    Lamont G
    We need a more robust OBJ import/Export NT ^_^!! Or someone...
    San Antonio, Texas, USA
    13,057
    Just a point, it needs an OpenGL 2.0 compliant card (appears my one at work isn't)
    UI / UX Designer @ NewTek
    North Carolina
    11,399
    I plead ignorance. Why would we need this and what is ambient occulsion? The lighting effect I saw on the site is really nice but are there game engines that support this kind of effect?
    Here is a page on Ambient Occlusion ::LINK::
    A good use is it gives depth to objects with a few params. It's fast as ****, and can make an object look "GI" lit when used properly.
    For games, it's just one more tool to get the look we want w/out asking the engine to do it for us. Use it to define muscles on a character... make dirt, all kinds of stuff. Get nice soft shadows in good time.
    Apply the result to vertex colors and it saves you a ton on lighting in-game. Just light the character and a few objects.
    Lamont G
    LightJustice Panikos's Avatar
    Nicosia Cyprus
    1,727
    Ambient Occlusion "looks" like GI but its not.
    Ambient Occlusion shows the accesibility of the geometry to the Ambient Light, often white.
    GI involves light bounces, indirect lighting. color bleeding, caustics plus ... plus ... etc
    Its a mistake to equalize the two or compare them cause they are different and of different value.
    Dec 2004
    London
    4,502
    Quote Originally Posted by jasonwestmas
    The main use for this is to render the ambient occlusion and apply it as a texture map, not to render it in real-time.
    Are my spline guides showing?
    North Carolina
    11,399
    Ohhhh, so it's like baking in Global Illumination (Reflective/ Ambient Light) into the color texture. Very cool idea! I love reflective lighting.
    Thanks guys!
    Faogen updated to v1.1 - http://www.rusteddreams.net/faogen.html :
    - Improved quality of generated AO maps
    - Object selection by picking them with mouse in viewport
    - Increased speed of loading high polygonal objects
    - Better UI allows to re-generate AO only for selected objects
    New calculation mode weights generated AO by cosine of angle between sampling direction and surface normal. This gives sharper result. Calculation mode used in previous version still available - just set CosineMode to False.
    Detailed help file will be released soon.
    How about some native LWO support? I'll love you till the end of time!!
    Can the OBJ format support vertex colors? I would like to get the vertex color info out of FaoGen into Maya or LW.
    Lamont G
    Quote Originally Posted by Lamont
    OBJ didn't have vertex colors - calculated per-vertex data is saved into U texture coordinate. I don't know if there is an easy way to convert it to vertex color inside Maya and LW.
    Faogen 1.1 has support for format plugins (currently just as experiment - some things will change in next version). And first plugin will be for LWO
    Sweet!! Support vertex colors!!
    Lamont G
    Faogen 1.2 - http://www.rusteddreams.net/faogen.html
    added LWO I/O.
    LWO saving from Faogen is in beta state - not all features exported correctly yet, but this should be fixed soon.
