Thread: "Predeator" effect
    "Predeator" effect
    I want to make a transparent monster (sort like "Predeator" movie), but I do not want to
    render the background sequence and will use a still image
    for background, how do I set the surface for this monster?
    (Assume there is only 1 material for this object)
    Thanks!
    Sep 2005
    Las Vegas
    711
    I'm not entirely sure what you're trying to achieve. If youre trying to get what I think youre trying to get, I don't see what the problem is...
    I would just use a polygon that has your still background behind the charater, and use an alpha channel to extract it.
    satellites & astronauts ercaxus's Avatar
    NY
    620
    take a look at this tutorial from Dave Jerrard (he who is the man when it comes to stuff like this)
    http://www.spinquad.com/forums/showp...08&postcount=4
    Thanks!
    I will try your suggestion!
    By the way, I have a question, what do you means by using a
    aplha to extract the background?
    Thanks!!
