Thread: Adaptive sampling switches off
    Jun 2003
    London, UK
    8
    Angry Adaptive sampling switches off
    I've upgraded to LW8.5 and I've found that I have a moire pattern appearing on one of my renders, so I stuck Adaptive sampling on and hit render.
    When I looked at the rendered image the moire still existed so I checked the camera settings to see if something else could be changed to help and I noticed that Adaptive sampling had switched itself off!
    Now two questions spring to mind... Other than how do I fix this
    1. If Adaptive sampling switches itself off when I check the camera settings did it actually get used in the render?
    2. Will adaptive sampling solve my issue anyway
    Any help at this point most appreciated... I have to say at this point I am not terribly impressed with 8.5
    Lightwave 7871
    There is no dark side of the moon, matter of fact its all dark!
    Dec 2004
    London
    4,502
    Adaptive sampling will probably not help you. Just turn up the anti-aliasing. Or activate mipmapping for the texture map causing the moire patterns. Or, if the moire appears in the background, use depth-of-field to blur it out.
    Are my spline guides showing?
    Sydney
    8,275
    You have to increase the AA setting to more passes or turn up the mipmapping strength in the moire texture's panel.
    Adaptive sampling will only turn itself off when you render if you're using Saslite, since this doesn't render correctly with it on.
    Jun 2003
    London, UK
    8
    Cool
    Quote Originally Posted by Dodgy
    Ahhhh Saslite! Now that makes sense......
    I'm using Saslite to create tinsle.... all becomes clear now...
    Many thanks for that !
    Lightwave 7871
