Thread: ghosted menu
    ghosted menu
    I should know this but I can't figure out why items such as the example in my screen capture is ghosted when I clearly place it in the config. Notice in this example for "Dynamic Obj" that there is no "dot" in the config menu and it is also ghosted in the main menu.
    William
    realimagesvideo.com
    Mar 2004
    Northern New York
    5,254
    Try rescanning your plugins and see if that takes care of it. If not, then delete the config files, rescan plugins and reset menu to default.
    Silk
    Quote Originally Posted by Silkrooster
    Silk
    Yep. That took care of it. Thanks!
    William
    realimagesvideo.com
