Thread: Surface Texture Image Inverted
    Oct 2005
    chicago
    2
    Problem with inverted surfact texture image
    Surfacing a box, the front and one side of the box take images correctly. The back and the othe side apply the images inverted as if looking in a mirror. How do I flip those inverted images to be able to read them normally left to right?
    Thank you.
    Banned
    Apr 2005
    Valencia
    3,145
    Are you using the same surface to texture both sides of the box?
    If the answer is yes, the imge it is being proyected through that axis, so change the surface of on the box faces to another surface and put negative values on the size values for the texture to flip it.
    Cheers, David.
    Dec 2004
    London
    4,502
    Use UV mapping.
    Or at least cubic mapping.
    Confirmed -
    Oct 2005
    chicago
    2
    Thank you.
    yep.
    select your front polygon.
    Make Uv map planar Z (automatic on)
    select your back polygon make the same projection
    And flip your uv with the options in Map TAB
    Cheers!
    Operation
    Mourad K.
    www.mouradkechar.com
