Thread: An easy one (I hope) for the LW vets...
    World's Tallest Dwarf safetyman's Avatar
    Maryland, USA
    1,351
    Question An easy one (I hope) for the LW vets...
    I'm relatively new to LW, and this one should be easy for the "vets". Every model I import (.obj, legacy .lwo, etc.) has white lines in the shaded wire view, instead of my default dark blue. Any way to make them revert to my default so that I can see them better?
    Huge Member mkiii's Avatar
    West Sussex UK
    1,102
    All you need to do is select the object, (all polys selected), press i to get the info window up, then select the line colour you want in the dropdown menu at the bottom.
    Beware. This may be quite slow to appear if it is a high poly model, but it will pop up eventually.
    A BUG PLANET. duke's Avatar
    Melbourne, Australia
    708
    Alternatively, use the reduce points tool (it scans the mesh and will revert it to the default blue lines). It's under construct tab, use default settings. If the imported model has a UV map unweld the points first, then run reduce points, then weld. So ctrl+shift+u to unweld, construct->reduce points, m for merge.
    Maryland, USA
    1,351
    I knew you guys would respond quickly -- thanks so much for your help!!!
    Sydney
    8,280
    Alternatively use Detail>Polygons>Sketch Color to set your poly's sketch colour, and then use Default sketch colour in the display options to set what colour all new polys should be. The use the colour wireframe view modes or sketch modes to see them in glorious colour.
