Results 1 to 2 of 2
Thread: VIPER and Transparency
    Registered User mrunion's Avatar
    Jonesborough, TN
    582
    Question VIPER and Transparency
    Forgive me asking this if it is something I should have already found (but a quick search or two brought up nothing). I am using VIPER to tweak some surfaces, but things that are transparent (a.k.a. glass) just render as the "background" color that the Surface Editor uses.
    For example, if I set the Surface Editor background to a checkerboard, the VIPER display shows my glass surface as a checkerboard. If I use black for the background, black shows up in VIPER.
    The glass I modeded is sitting in front of a plane with an image map on it. When I actually do a rednering (F9), I see the image "through" the glass, but VIPER does not show this.
    Am I missing something, or is this normal?
    I go now to read the manual......
    Thanx,
    Matt
    (I will come back to LightWave3D when the support Linux. Linux isn't going anywhere, guys. Time to accept it!)
    Cleared of all charges
    Utah, USA
    238
    this is normal. viper has some limitations.
