Thread: UV Help
    Greytown, NZ
    127
    UV Help
    I'm trying to get an image to sit on the top of a can, and then wrap over and down the side.
    Can anyone help with the UV maps?
    Do I need to set up two UV maps - one for the top and one for the side and then pull points to match it up, or can I get away with using one?
    Cheers
    Dave
    Ooohhh, my brain hurts
    Sydney
    8,276
    You can use one. Either unweld the seam points to move them around (7.5 and earlier) or use the Free move mode in LW 8 to move the points to match.
    Back from Monkey Island Weetos's Avatar
    May 2003
    France
    943
    In this case you can have only one UV map, there's absolutely no need for two imho
    Cheers
    Weetos
    Greytown, NZ
    127
    Thanks for the help guys. My brain was turning to mush trying all of the UV options. Now I'll stick with a planar UV along the Y axis.
    Thanks again
    Dave
    This one is simple enough for me to do - Create a UV map, Planar type, on the y axis. In the modeler viewport, select all the points on the bottom of the can. In the uv texture window, scale those points up so they spread out from the rest of the object. Apply your texture in the uv viewport as well as the modeling viewport so you can see how much to scale up.
    Confirmed -
