Thread: How to change the render size
    Registered User jnddepew's Avatar
    May 2005
    NYC
    509
    How do you change the size of the final render?
    Select Camera Properties and you can change resolution prior to rendering. You can use one of the presets from the drop down box or manually type in the width and height values.
    If you want to change the size after you've rendered, you can use Photoshop or a compositing program to change the size as well.
    May 2005
    NYC
    509
    thank you.
