Thread: Motion Blur & Animated Filters
    I know is probable that this isn't possible, since is a change that one makes in pre-processing, but it would be good for some illumination tricks if MB worked with envelopes assigned to Image Filters in the Image Editor.
    Gerardo
    LightJustice Panikos's Avatar
    Nicosia Cyprus
    1,727
    ImageFilters are performed after the rendering is complete
    MotionBlur is applied in every AA pass, so there is no way to link MotionBlur with ImageFilters.
    MotionBlur and PixelFilters play well together.
    Of course you can have Envelopes with animatable parameters in the ImageFilter (see HDR_Exposer for example) but these changes work on a per frame basis without any MotionBlur.
    Hope this helps
    Thank you for respond, Panikos. I had already noticed that, neither it works in postprocessing. For that reason my request of having an option so that in some way the envelopes in preprocessing works with MB.
    There are some other options that would be also very useful if they worked in preprocessing, as gradients input_parameters for example
    Gerardo
