Thread: Tagra to DVIX AVI
    Tagra to DVIX AVI
    What is the best and cheepest program to convert Tagra files to AVI? I have been using Screamernet and now need to compile the files to an AVI format.
    Dave.
    you shuld be able to get an old version of adobe premiere for very cheap - DivX uses installed codecs. Look for a version of 4.2 or something.
    saw this on UK ebay -
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...152561523&rd=1
    dont know where u are...
    Beyond Reality WizCraker's Avatar
    Clovis New Mexico
    1,410
    You could also just use Lightwave to save the image sequence into the .AVI
    1. Just load the image sequence in the Image Editor, then press CTRL + F7 For Compositing and select the Image Sequence as the Background Image.
    2. Go to your cameras properties set the size you want to render to.
    3. Next go to Render options, click output Files, Animation File type in name of animation.
    4. Type .AVI Options DivX Codec Configure to set your options [PRO gives you more of course] Press OK, OK Again, Close out Render Properties.
    5. Press F10.
    It will finish pretty quickly usually at .1 seconds per frame. If you are looking for batch style then might have to purchase something like Cleaner.
    ImageReality.com
    "Relax...it's just an update for the patch to fix the nerf that nerfed the fix for the update of the patch that broke the fix that was fixed."
    Late 2013 MacPro 12 Core
    VirtualDub
    Your best bet is VirtualDub, and it's free! you can get the standard version from here:
    www.virtualdub.org
    There's also a version that reads MPEG-2 files and you can download it from here:
    http://www.free-codecs.com/VirtualDu...2_download.htm
    Tell me how it goes.
