Results 1 to 14 of 14
Thread: Does the Linux MAC LWSN from 7.5b work?
    Digital Ho HowardM's Avatar
    London, England
    1,042
    Finally got our screamernet working on our MAC network and was wondering if we could get our LINUX boxes working?
    Even though the MAC 7.5b upgrade was screwed, will the linux LWSN still work if we try it?
    Otherwise, how can we get our Linux boxes working with our Macs?
    Thanks!
    Registered User wapangy's Avatar
    Colorado Springs CO, USA
    213
    When I tried it, the linux nodes would not show up in the network rendering window at all, I don't think NewTek even tested the linux nodes on mac at all.
    You can try the -3 mode by them selves, but even that can be tricky.
    Pixel realestate agent
    n
    1,563
    wat linux for ppc u using?
    213
    not on ppc, redhat on athlon
    London, England
    1,042
    Angry
    after hours and hours we got linux lwsn to see the MAC, and vice versa...and even got screamernet to recognize the linux node...but of course once I hit render the linux node just rifles thru and doesnt render a thing!...and we even made a separate config file for linux!
    I seriously doubt Newtek tested the Linux LWSN with a MAC!
    its impossible to get both to understand correct naming conventions...
    im pretty damn pissed after wasting a day with 2 IT guys...getting it to almost work, and then nothing!
    Thanks alot NT!
    Howard, are you sure it didn't render anything, or maybe it put the renderings somewhere obscure?
    First time I tried a render with normal screamernet, I couldn't find the file it had supposedly rendered, either.
    "Between midnight and dawn, when sleep will not come and all the old wounds begin to ache, I often have a nightmare vision of a future world in which there are billions of people, all numbered and registered, with not a gleam of genius anywhere, not an original mind, a rich personality, on the whole, packed globe."
    -- J.B. Priestly
    London, England
    1,042
    yeah im sure...the linux node would just start rendering 2 segments (which means it didnt read the correct PREF files from the MAC, nor when we set prefs on the linux box), then it flys thru each frame, not rendering anything, and finally saves no where....
    so weve decided to go with an all MAC render farm....crazy eh?!
    Registered User bool's Avatar
    Washington State
    42
    Try this tutorial. It works for Windows, but it could be adapted to work for Mac as well.
    http://lwbeginner.hypermart.net/lwsnlinux.html
    Washington State
    42
    One quick question:
    What does a shared directory structure look like on Mac? For example, with Windows, you would map a directory and it looks like a drive. (ie. C:\LightWave mapped to Z:\ then Z:\ becomes that directory)
    -Bool
    213
    Originally posted by bool
    One quick question:
    -Bool
    On OSX all the volumes are in /volumes/ like this...
    /volumes/nameofthevolume/
    Washington State
    42
    Smile
    That seems like it should be easy then! You should be able to simply re-create the directory structure on Linux as it is in Mac (in theory). However, I have never used the Mac version of LW, so I can't be too sure of that.
    I've put up a tutorial (location earlier in this thread) that works for Windows, but you might have to edit the watch.sh script where the line looks something like this:
    sed s/$MAP\:\\\\// tmp > job.1
    to look more like this:
    sed s/\\/*$MAP\\/// tmp > job.1
    Where $MAP is actually the base shared directory. Make sure to set your content directory with the '-d' switch. But if you get everything working, don't expect to get surface smoothing to work. If you do, let me know! :-D
    Hope that helps!
    -Bool
    213
    Yeah whats up with no surface smoothing anyway? I never understood that one.
    By the way, one of the troubles is that
    windows uses \
    OS X uses /
    but LightWave for OS X uses :
    (which is the old OS 9 style)
    for directories
    Crazy World
    n
    1,563
    Mandrake 9.1 is out for PPC, and YDL is out in a few days... Anyone got any info to share about which is better?
    Washington State
    42
    windows uses \
    OS X uses /
    for directories
    Crazy World
    Well, one of the cool things about mounting a directory (at least using SMB) is that when you mount it, it should take on the charactaristics of that type of OS. So, technically, the '\\' should work in Linux in that mounted directory structure...
    -Bool
