Thread: How do you get objects to follow each other
    Dave W.
    Nov 2003
    Cleveland, Ohio
    135
    I am tring to get what looks to be t.v. screens to follow each other. For example if one banks the others following behind will bank and will move together. I usually do modelling and stills but I would reallly like to do some animation of this, please help!
    modelling is a way of life
    press "m" for motion options, and than use "follower". make the object follow the first one and animate the first and every one else will do the same.
    Hastings, New Zealand
    7,731
    The simplest way is to select all the TV monitors and rotate them at the same time.
    After that you have as coremi said, follower, channel follower, expressions and so on.
    Dave W.
    Nov 2003
    Cleveland, Ohio
    135
    I've benn playing with follower, and I have had a great deal of fun with it but one thing I would like the screens to follow each other and then be able to follow one another into a circle and so far with follower I can't get them to go off of a straight line.
