Results 1 to 2 of 2
Thread: Selecting points in between
    Anyone know of a plugin or a way to do this? I have selected two loops of points - for example suppose I had a long tube and I select some at one end and some at the other, now I want to select all the points in between these two loops. Any way to do this?? Obviously the piece is more complicated than a tube. Thanks!
    well - I figured out that I could select all polys and hit "select points" under the selection menu. Didn't realize this did this. It doesn't do exactly what I wanted but it works
