Results 1 to 15 of 15
Thread: UV-Maps get deformed
    Apr 2004
    Hampshire, England
    28
    When I make a new UV-map on an object the UV is distorted and out of proportion. So when I paint the image using the UV as reference that will also be distorted. So when it gets mapped onto my object it is all stretched out and wrong.
    My object is not a complicated one. I've even gone as far as flattening out the model using endomorphs to try and get a better proportioned map; same result. Bit at a lost now, not sure what Iím doing wrong if anything.
    Any help would be great, textures arenít my forte.
    Sydney
    8,276
    Quote Originally Posted by red fox
    Have you tried unwelding all polys before applying the mapping...
    Apr 2004
    Hampshire, England
    28
    Yeah, I think I've done every thing. The problem is with the shield, the colour map is stretched along the Z axis. Iíve tried using planer and atlas texture maps but they look distorted, using them for a reference to paint a colour map ends up with what I got, stretched UVís.
    Apr 2004
    Hampshire, England
    28
    The UV is elongated in the Y or V axis.
    Sydney
    8,276
    You do realise the Uv map create only gives you a starting point for your mapping? That you can then modify the uvs (by scaling moving etc) to give a better reflection of your model's shape?
    Apr 2004
    Hampshire, England
    28
    Errrrrr.....no I didnít. I knew that I could unwield UV poly's and then move them....didnít occur to me to try and scale it.
    Such a simply mistake has taken me a week to sort out.
    Cheers for that will try it now.
    Pessac
    5,067
    Also, it may be better for you to select individual polys, rather than the whole object, and just UV map them - especially since you seem to be texturing the shield that way because it's more difficult with the traditional projections? That way you'll get more control over the placement of the images in the UV texture window...
    B
    LightWave 3D Trial Edition
    Are we there yet ?
    UK
    527
    By default LW's default UV mapping projections will non-uniformally scale your selection to fill the 0,0-1,1 UV grid. This means that unless your selection is square to start off with, it will be stretched to make it square.
    One solution to keep your selection in the same proportion is to draw a cube around it before applying the UV map (making sure that no part of your model is outside the cube), apply the UV projection to your selection, including the cube, then delete the cube.
    Custom User Title
    Huddersfield, Yorkshire, UK
    776
    Quote Originally Posted by Yog
    A better solution is to use the Texture Guide 2 plugin. Sorry Yog, but the cube method is a bit old school!
    Red Fox, like they said, any of the UV mapping tools just give you a starting point. you will then have to modify the UV points to reduce distortion. Apply a grid pattern to the colour channel while you`re doing this and you`ll see the errors more clearly!
    Cheers,
    R
    Are we there yet ?
    UK
    527
    Quote Originally Posted by Rory_L
    R
    Heh heh, "Old school" is me all over
    I still find that I often parent cameras to a couple Nulls to split out movement/rotation channels. My poor old brain can't cope with this new fangled per channel key framing
    Apr 2004
    Hampshire, England
    28
    Cheers guys, all sorted now. Will post the final model soon as Iíve finished the other maps.
    How Old? Really? Aww Heck colkai's Avatar
    Staffordshire
    7,809
    R
    Care to expand on that? Is it just a method of sizing the texture? If so - how does that help the creation of the UV map?
    Too old to die young.
    Sydney
    8,276
    It's an alternative version of the texture guide tool which works a bit better than the old one. So basically it's an interactive way of uv-mapping vertices....
    Staffordshire
    7,809
    righty - must take a peek at that - ta Mike!
    Custom User Title
    776
    ...And holding `Control` as you resize the widget maintains aspect ratio. It`s a cool plugin!
    R
