Thread: missing images
    missing images
    Anyone else ever have the annoying problem that scenes files do not remember where to access preset texture images? Regardless of where my files are saved or where the content directory is, I always have to load the preset images seperately. Is there a bad path embedded in the surface files somewhere? Any ideas?
    7.5 on Max OS 10
    ex-LightWave documentation BeeVee's Avatar
    Pessac
    5,256
    If you are using your Content Directory correctly the problem should never arise. If you use images from outside the Content Directory path you have set, then you will always get trouble when using images...
    B
    Ben Vost
    LightWave 3D Docs wiki
    AMD Threadripper 1950X, Windows 10 Pro 64-bit, 32GB RAM, nVidia GeForce GTX 1050Ti (4GB and 768 CUDA cores) and GTX 1080 (8GB and 2560 CUDA cores) driver version 456.71, 2x4K 23.5" monitors
    Member etobiason's Avatar
    Dec 2003
    Chicago, IL
    665
    When you say "preset images" I imagine you mean the images that came with LW, the ones that are in the LW content folder, maybe reflection maps.
    Copy the ones you are using into the Images folder within the content directory for the job, and they will be accessed properly.
