Thread: How do I 'slightly' spherize' an object?
    Registered User Bliz's Avatar
    Dec 2003
    London, UK
    280
    I'm sure I used to know the answer to this but it eludes me now.
    I want to deform an object part way between it's original state and it's state after a 'spherize' operation. There's no numeric option for the spherize tool.
    I could do it as a morph but I vaugely remember being able to do it with a native plugin?
    It would also be cool if I could 'cylinderize' the object instead of 'spherizing it, i.e. just rounding the object in one axis.
    Thanks in advance for any help.
    Cheers,
    Bliz::..
    My homepage
    www.anthonyrosbottom.artstation.com
    Hello!
    I would do it this way:
    Create a new endomorph, then spherize that.
    Use the Apply Morph tool and set the percentage to whatever you want and apply it to your base- mesh. Hope that helps.
    CU
    Elmar
    Dec 2003
    London, UK
    280
    Cheers Elmar,
    I did what you suggested which worked cool and then immediatly after found out what I was looking for in the beginning.
    Construct > Additional > Spherize2
    Cheers,
    Bliz::..
    My homepage
