Thread: uv texture question
    tampa/hudson, fl
    91
    uv texture question
    I have been going through dan ablans inside lightwave 7. I tried to create a uv texture using the method described but it didnt seem to work. I loaded the object. then clicked on the t in the bottom right hand corner. Then when I tried to change the view to uv texture that option is not listed. i am working with 7.5. what am i doing wrong?
    Jun 2003
    USA
    47
    did you hit new on the drop down menu.. towards the right?
    tampa/hudson, fl
    91
    yes, renamed it and everything.
    Jun 2003
    USA
    47
    which chapter are you talking about..
    in order to see the uv texture, have you assigned the uv map through the surface editor an image?
