Results 1 to 15 of 17
Thread: Is subsurface scattering very hard to implement?
    Is subsurface scattering very hard to implement, perhaps they (the developers) were very busy at those new aa features. LW 8.2 still doesn't have SSS, someone said the raytracing functions of LWSDK need to be improved, but I don't see any improvement about raytracing functions.
    When can we get this? Sigh... I don't want to use other 3d software just b'cos of SSS. I hope newtek will add this common feature in next version.
    p.s I have tried G2, it might be due to the limitation of LWSDK, but the fact is its SSS is really not that good. Compared with Brazil and Mental ray, their SSS are much more impressive.
    LightJustice Panikos's Avatar
    Nicosia Cyprus
    1,727
    I guess you saw some images from top-artists of Brazil / Mental Ray.
    How much time you spent on G2 ?
    I am quite satisfied with it.
    Quote Originally Posted by Panikos
    Not only top artisits, many users showed their images with impressive SSS.
    I used G2 since the first version of G2. I have spent so much time on G2 SSS, but I could not get a good result. especially the radiosity is on.
    Unfortunately, I have not seen any impressive image with g2s SSS by any LW artist. I would love to see if you know any good LW artist who did a good job with G2 SSS.
    Banned oDDity's Avatar
    Jan 2004
    Northern Ireland
    1,517
    And G2 sss doesn't work proprerly with area lights either. Being reduced to working with spotlights is really scraping the bottom of the barrel.
    Nicosia Cyprus
    1,727
    Yes, Area lights & G2 is a problematic Combo.
    But ...
    here are some images I did
    But Point arrays will do the same job and work fine..
    Quote Originally Posted by pooby
    how many point light did you use for 1 light source?
    I used about 20 parented to a spinning null with motion blur on and low antialiasing.
    If you set up a light array with sliders to affect brightness and colour, then you can save that scene out and just import it whenever you need an 'area light'.
    It has other advantages to an area light too. you can turn off specularity for some of the points, thus being able to control the overall specular effect of the light array.
    Plus is doesnt have that weird dark spot at the edge like an area light has.
    It also has no noise at all..
    Why motion blur is on?
    Can you post capture a screenshot that how your lighting setup look likes, if you don't mind?
    thanks a lot
    The motion blur smooths the array out to avoid sharp edges and artefacts.. that's why you have the spinning null..
    If you didn't have motion blur, you would need 5 times the amount of points
    Quote Originally Posted by lw3d23
    thanks a lot
    It's the famous spinning lights trick. A quick google search should find tons of info about it.
    Samuel Kvaalen
    [www.kvaalen.com]
    It's not the standard spinning lights trick though.. That uses a shadow map spotlight as I recall.. this is a bunch of points, but the basic theory is the same.
    Quote Originally Posted by Kvaalen
    I know the common trick, but I gues the trick that pooby using is a bit different than the common spinning lights.
    Dreamer Ztreem's Avatar
    Jun 2003
    Sweden
    4,129
    I use a similar setup with pointlights to get softshadows. But I don't use the spinning light trick, I use shadow noise reduction to get rid of the banding in the shadows. You can check this thread out, I also share a setup there.
    Jun 2003
    Sweden
    4,129
