Results 1 to 2 of 2
Thread: Some trouble with 8.1 and Hypervoxels
    France
    125
    Some trouble with Hypervoxels
    Since I installed 8.1, some scenes do not load. Seems to be related with hypervoxels or particles. Beside a scene of my own, 'type21' (surfaces), 'Skull_bot' (hypervoxels), and some other HV scene from LW8 content make the layout crash on loading.
    LW 8.1, winXp pro. Tried on another computer with Win2K : same problem.
    Any idea?
    HD
    <edit>
    Went back to 8.0 : no changes. Not a 8.1 issue after all. Must be some plugin issue
    Chief Noob Hoopti's Avatar
    Mar 2004
    Mooresville, NC
    435
    I've only had this issue once, and it happened to be today. The scene file loaded fine in 7.5 but wouldn't load in 8 or 8.01. I had applied HVs to an object itself, not using the object as an emitter, just using the HVs on the points/vertices as a texture. When I did get the error message crashing LW 8, I got it on the gcore8.dll. Only thing I've been able to find is if I don't have the legacy plugins loaded, it loads fine 95% of the time. Still get some crashes but nothing like I did before (everytime).
    Hoop
    www.mean3d.com
    "Problems worthy of attack, prove their worth by hitting back." -- Piet Hein
