Thread: Welding
    Registered User chemaelizondo's Avatar
    Mar 2004
    Monterrey, Mex.
    237
    Welding
    Hi guys.
    I have a good question for you all:
    Does any one know if there is a way to have several points welded independently?
    By this I mean, not weld them all in a single place, but rather to weld overlaping points, all at once instead of having to identify and weld each of them at the time.
    JM
    Jose Elizondo
    www.jmelizondo.com
    LW9.6
    Mac
    Dual 2 GHz, G5.
    Press 'm' to merge points -
    Confirmed -
    Mar 2004
    Northern New York
    5,254
    Merge will work, if they are perfectly aligned. If the points are slightly off, you can lasso select the points then weld. Also I think merge can be set to manual, so you can change the offset, like I said, I think, as I have not played with the setting for the merge tool in the numeric panel, very much.
    Silk
    Yes, within the merge numeric panel you can enter a distance value and it will merge points that fall within that distance in case any of your points are slightly off but I wouldn't recommend using it because you might merge points you don't want to. I would just turn on subpatch and you'll see where the points aren't connnected.
