Results 1 to 10 of 10
Thread: Spreadsheet crashes LW8
    Unhappy Spreadsheet crashes LW8
    This is weird:
    Every time I call (Scene > Utilities: Generics > Spreadsheet) LW8 crashes.
    Even a new scene. Anybody else had this problem? Any suggestions?
    p.s. works OK for me in 7.5c
    Somewhere, over the rainbow....
    How Old? Really? Aww Heck colkai's Avatar
    Staffordshire
    7,808
    search out your spreadsheet.cfg and delete it and see if that helps.
    I have the odd crash due to spreadsheet myself, this usually sorts it
    Too old to die young.
    Colkai, when I read your suggestion, I was convinced you were right.
    But unfortunately, it still crashes.
    Some folks on IRC suggested it might need an updated video driver
    But this is the only thing that is crashing my LW8.0.1 so I'm skeptical.
    Staffordshire
    7,808
    must admit - i'm running 8.0 so can't offer any insight there I'm afraid.
    does it do it in a blank scene? or is it just in an existing scene?
    If it is only in existing scenes, check the scene file nad remoe any reference to the spreadsheet from the master plugin area, (having copied your scene file firstof course ).
    Even a new (N) blank scene can't call up the Spreadsheet Editor.
    It always displays the panel for half a second and then crashes (shutsdown) LW.
    As I mentioned, it works in 7.5c
    state of confusion
    6,973
    Same here
    never been able to get it to stay open on either ATI or NVidia card.
    New blank scene or full spread scene and objects.
    And the other scene spreadsheet sucks (sorry Newtek)
    when I check a box I want it checked and not have to go to another requester to click toggle and apply.
    If I didn't want it toggled, I wouldn't have clicked on it in the first place.
    Skype...lost_in_3d_space
    Sager
    I7-4800 OC'd to 3.3 GHz
    12G 1600mhz mem
    256 gigs raided SSD drive
    Hastings, New Zealand
    7,731
    Try renaming your config files and restarting LW from scratch. The scene editor runs fine on my machine(s)
    Larry,
    What a double edged sword!
    Your suggestion worked.
    But if I use the default, I lose all that neat customization I've done over the months.
    Where that weeping icon? boo hoo....
    ps. oh and thank you for your suggestion...it's appreciated.
    7,731
    I agree, its a real pain. You might see if you can salvage your Tabs with this plugin called interface builder and load them into a new config.
    http://www.learnlightwave.com/interface_builder.htm
    Quote Originally Posted by GregMalick
    Larry,
    • There was alot of talk about this 7.5 SS crashing thing when L8 was 1st
      released. That might be it. The solution that always seemed to work then
      might work here as well.
      Create 2 shortcuts one for modeler.exe and one for lightwav.eve
      Name them LW7.5 and Mod7.5 (or anything you want really - and
      then open the properties panel and and make use of the config
      location directive. Mine looks like:
      G:\LightWave_3d_7.5\Programs\lightwav.exe -cG:\LightWave_3d_7.5\Configs
      Now create a folder inside the x:\LightWave_3d_7.5\ named "Configs" and
      move your config files for L7.5b into that folder.
      Then just always start LW by the shortcuts and you'll be ok. To ensure that I
      do I also add a hotkey to the shortcut properties panel. Here"s my panel for
      LW8
    • Note: in the Japanese OS the root "/" foreslash character shows up as a yen
      mark so just replace that with the proper foreslash "/" key if you decide to use
      this solution
