Thread: Wave Filter
    Registered User Cunhambebe's Avatar
    Sep 2004
    São Paulo - Brazil
    206
    Wave Filter
    Hi there, I'm a newbie and I'm having a hard time trying to find wave filter so as to set NTSC safe colors. Can anyone please help me how to enable it? I've read and read and found nothing. THKS!
    Sleepless exit6's Avatar
    Jul 2004
    NYC | CT
    163
    I've bumped against this a little. As a rule, I never use black, I go RGB 35,35,35 and I never use white, 235,235,235. I've never heard of a filter for Lightwave although I would like one. Avid has a color correcter built in and most editors know how to get the levels right. When I run into trouble I run my renders through After Effects and correct it there.
    Hastings, New Zealand
    7,731
    In the Effects Panel under the processing tab you have:
    Wavefilter
    NTSC Legalize
    Pal Legalize
    Video Legalize
    There also might be some free plugins as well.
    This could also probably be done in post.
    Sep 2004
    São Paulo - Brazil
    206
    Thanks to all who took time to respond, really. I'll try to use Vegas instead of After Effects and searching in the Effects Panel too.
    Jul 2004
    NYC | CT
    163
    Wavefilter
    NTSC Legalize
    Pal Legalize
    Video Legalize
    I didn't realize you had these within lightwave -- I think you're better off doing it this way than in post, because a filter in post might effect colors that are ok a bit as well.
    7,731
    Theres a lot of tools like that in Lightwave. In the same panel theres about 7 image savers that many dont know exist.
    Sep 2004
    São Paulo - Brazil
    206
    Thanks to all for the help
