Thread: 15 fps to 25 fps
    15 fps to 25 fps
    I don't have much time for rendering an animation. I thought of rendering a 15 fps images sequence and import in After Effects in a 25 fps composition.
    Did anybody made already some quality tests?
    Thanks for replying
    Quote Originally Posted by hiromiito
    Thanks for replying
    you could get pretty good results (sometimes) with:
    http://www.revisionfx.com/rstwixtor.htm
    may the luxigons be with you!
    I'll try that. And post my comments.
    If only I can solve this problem: I'm using the skylight rig trick and the animation rendered at 15 fps shows spinning shadows! No problem at 25 fps.
    Any idea how to solve that?
    Thanks anyway for the Twixtor tip.
